Getting the axle seal in straight
Old Feb 27, 2017 | 05:04 PM
Shrout1's Avatar
My saga continues...
I am replacing both half shafts on my 99. I bought new axle seals.
I've replaced the axle seal on the driver's side, but it certainly did not go in straight. I've gently tapped the non-cooperative side in... but I can tell that the seal is skewed.
I could pull the seal and order... another... new one...
I haven't tapped the seal all the way back in its housing - there is an uneven gap between the back of the seal and the wall behind it.
I have a 36 MM socket that *almost* works... Looking for tips.
Old Feb 27, 2017 | 05:18 PM
Shrout1's Avatar
Just ordered a bearing race & seal installer kit which has diameters that *should* be good for this job... 2 more days... I'm hoping I can unscrew the seal by tapping it in the rest of the way. It's probably skewed by about fifteen degrees.
Old Mar 1, 2017 | 04:46 PM
RA030726's Avatar
I'm nutty for Nissans
I bought a short piece of black iron pipe and cap from the hardware store that was the right diameter.
Old Mar 1, 2017 | 05:43 PM
CS_AR's Avatar
Opps - Wrong thread..
Old Mar 1, 2017 | 10:50 PM
KP11520's Avatar
Nothing like^^^^^^^^^ Nissan Specialty tools! LOL
I like creativity at the right price!
But seating the Race really needs the right tool.
Old Mar 2, 2017 | 02:20 AM
CS_AR's Avatar
Good catch Keith. I removed my CV axle example.
Old Mar 2, 2017 | 09:49 AM
DennisMik's Avatar
I used 2" pvc pipe for the passenger side and just my hammer for the left side.
Old Mar 2, 2017 | 04:33 PM
KP11520's Avatar
Hi Dennis,
My luck usually has a dark cloud when I try. I've been beaten up too often, and as a result, just go conservative!
I'm going to borrow some of your good luck next time if I may! Man, I seriously need it!
Old Mar 2, 2017 | 04:37 PM
KP11520's Avatar
You didn't need to do that. I learned from that post! And I do respect creativity for sure. So many times, that's what actually gets the job done!
Old Mar 4, 2017 | 06:56 AM
Shrout1's Avatar
Finally got it in flush! Used the bottom of my breaker bar like a dowel and beat on the metal on the socket end. Worked like a charm. Now to get the axle in flush...
