Air Bag light
Old Nov 14, 2000 | 06:09 AM
bamabob's Avatar
Air bag light just recently started flashing at me. Coincidently, I had just a day before cleaned the engine compartment. I quickly looked around to see if there was a fuse of some sort but couldn't find anything. Anyone know? I'd hate to take it to the dealer for something simple.
Old Nov 14, 2000 | 07:15 AM
Daniel B. Martin's Avatar
Here is the procedure for turning off the dashboard warning light.
This information is in the '99 Maxima factory service manual.
Open the driver's door. Note the rubber covered button located low on the
B pillar, a button which is pressed by the door when the door is closed.
This is the Driver's Door Switch (DDS).
Turn the ignition from OFF to ON. Press the DDS at least 5 times within 7
seconds after turning the ignition switch ON. Turn the ignition OFF.
Close the driver's door. Start the engine.
If there is a problem with your Supplemental Restraint System that warning
light will come back. Maybe sooner, maybe later, but it will be back.
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Sep 8, 2015 02:36 PM
sdotcarter
Sep 2, 2015 09:53 PM
A32goldylocks
Sep 2, 2015 06:39 AM
