Do I need a CAMBER KIT? Sprint w/ KYB
Old Jan 31, 2002 | 10:23 PM
perfectmax's Avatar
I have a 97 maxima and am getting it dropped. I FINALLY got KYB AGX with SPRINT springs. I asked custommaxima.com if i needed the kit and they said NO. I asked tirerack.com if i needed the kit and they said YES. What the DEAL??? I tried the search and it was limited. Whats your experiences with this? I got some dope tires and im not trying to kill them. If you think i do where to i get a kit and how much???
Old Jan 31, 2002 | 10:36 PM
BlkStnValyMaxima's Avatar
You don't need it.
Old Jan 31, 2002 | 11:01 PM
nigelcmf's Avatar
There's plenty to search on in the ORG.
It is said that if you don't drop more than 2" then you don't need the camber plates. I don't have personal experience of this ....yet!
Old Feb 1, 2002 | 12:27 AM
airmattdog's Avatar
Guy with the Orange Max
At least get camber bolts from http://www.tirerack.com I have the Sprint springs and I do have inner tire wear. They're only $30.
Old Feb 1, 2002 | 06:10 AM
JAY25's Avatar
Most likely you wont need them
I am at two inches myself I dont have camber plates or bolts, I did have the bolts and they make squeaking noises took them off. If you install these springs loosen the two nuts that hold the strut where the camber bolt would go and pull on it, that right there will give you back the camber therefor you dont have to get the bolts or plates, and your tires wont wear on the inside.
Old Feb 1, 2002 | 06:28 AM
perfectmax's Avatar
Re: Most likely you wont need them
Thanks guys! See, this is why i wanted to bring this up, because every has mixed feelings about this.
Scott
Apr 16, 2020 05:15 AM
maxima-junky
Oct 7, 2015 06:13 PM
Pied
Sep 26, 2015 03:29 PM
