95 Maxima Stalling Out
1st stall was coming off the freeway. As I slowed down, it died. I coasted to a stop. It cranked a few times and started. Drove a few miles home, stalled out while parking. Wouldn't start. Just cranking like it was maybe out of gas. An hour later, it started long enough for me to move it, but it was wanting to stall.
The next day, it started right up and idled fine.
Fluids are fine. Check engine was on when I bought it 2 weeks ago. It's off now. Oil light came on when I stalled. Oil is full.
I'm not a car guy. Please help me out.
Even though your CEL is now off, the vehicle still will store the codes for a period of time. Go to an auto parts store and have then pull the code, and go from there. If the code has already cleared, it is best to wait for it to come on again. At a guee, it could be the idle air control valve, but that is just a wild a$$ guess.
Like Rit said, go to Autozone or something and get the code pulled, since it is probably still stored in there. Let us know that code(s) you get. Even if you go to Autozone like Rit suggested, you should definitely buy a code reader because the CEL goes on a LOT on these cars! (You don't have to pay a lot of money for one, since eBay and Amazon have them at a good price, but get a name-brand scanner like Actron or Innova)
Even though your car is a 95, it still has the OBDII system, but the connector is in a different location than the 96+ cars.
I have been having the exact same smyptoms with my '95 Maxima. Yesterday it died and wouldnt start after driving it for about five minutes. This morning it started fine, I checked the codes (when engine was cold) and it was 5 long 5 fast (No malfunction). Then I started it again and this time let it idle and after a couple minutes it died. At this point I checked the codes and got a 5 slow 3 fast ( Front right O2 sensor) would that sensor malfunction cause the car to stall, and not start after it gets warm? It will start when I put the gas pedal to floor and crank and crank, and just run long enough to get home a couple miles away.. Any help would be appreciated
For the FPR, start by pulling the vacuum hose and see if any fuel is in there. If so, the FPR is bad. If not, it still could be bad and would simply have to be replaced.
Appreciate your help! Should the check engine light flash the proper code (Which is 09 08) if the ECTS was faulty? Thanks
Not sure. I can tell you from experience, that I've had a bad ECTS shut my car off while driving, and prohibit me from restarting until things cooled down....and no CEL.
Well, I had a friend replace the ECTS this A.M. During the trip to his house the car ran fine. (Of course lol) Dang intermittent problems are so frustrating! So we will see how it goes. O
O'Reilly auto parts had 2 possibilities, and each have different part numbers though they look almost identical. We compared both and chose the one that looked most like the old one. Also changed the fuel filter (argh!)...will report back if any more trouble..
We could get to it without having to futz with that bracket, he used a crows foot.
Also pulled the hose off the FPR, no fuel.
BTW....SWEEEET pic^^^!
