Coils not firing
Old Oct 25, 2017 | 06:38 PM
Charles Randy Phillips's Avatar
Coils not firing
Coils 1 3 and 5 fire but 2 4 and 6 don't this is a 97 maxima 5speed please help
Old Oct 26, 2017 | 01:08 AM
JoshG's Avatar
Get some new HITACHI coils, they run about $293 for all 6. My coils went bad last year in June, decided to replace all of them at once.. no problems after more than a year. I highly advice you to replace all 6, since if one is going out.. soon enough the next one will go and you will have to re-do the labor all over again.
Old Oct 26, 2017 | 01:15 AM
DennisMik's Avatar
Check to see if you have 12 volts on the red wire on each of those coils. Also check that the black wire has continuity to ground. Maybe you have a problem in the wire harness connector that feeds those 3 coils.
Old Oct 26, 2017 | 04:25 AM
I did they do have continuity and 12 volts plus if I plug them into the back coils 1 3 and 5 they will fire but they just don't when plugged into the front side
Old Oct 26, 2017 | 10:47 AM
JvG's Avatar
JvG
+1 On what Dennis said. Most likely a grounding issue. There are some ground wires attached to the front head, next to the uim. Remove the screw, clean the contactswith fine sand paper.
Old Oct 26, 2017 | 12:30 PM
You do realize that the front and rear coilpacks are different?
Old Oct 26, 2017 | 06:02 PM
yes I do I just stuck them on the rear side to see if they would spark but they did they just don't spark on the front side wonder what it could be i checked continuity it's good also they get 12v I also swap the computer with another one with matching numbers it does the same thing PLZ HELP.
Old Oct 26, 2017 | 06:16 PM
JvG's Avatar
JvG
Have you checked and cleaned the ground wires I mentioned yet? You might have 12v in the supply wire, but without a good groud, the coils won't fire.
Old Nov 15, 2017 | 07:42 AM
new battery and new starter but when I try to start it it drags slow until I hook up my battery bank tht goes to my system and it turns over like it should does tht sound like a ground issue. I'm going to clean and add more grounds cause the new deep cycle battery should spin the motor over just fine
Old Nov 15, 2017 | 07:45 AM
going to today cause with new starter and new deep cycle battery it should turn over fine but it turns over like a dead battery hope it's a ground issue. Is there anything else to try if tht ain't it.
Old Nov 15, 2017 | 12:45 PM
JvG's Avatar
JvG
I ran into this same issue when I was helping another member. They had a corroded negative wire from the battery cable to the frame. It would not allow enough amps to pass to allow the starter to get all the power it needs. They replaced that cable with a better one from the junk yard. Worked fine afterwards.
Electrical power travels from the battery, through an electrical device, then back to the battery. It seems that most members only want to replace expensive parts and batteries, while taking the main ground wire for granted.
I also feel that cleaning the grounds for the injectors will help fix that issue
