new transmission limitted slip dif?
Old Oct 29, 2017 | 06:27 PM
discobiscuit's Avatar
It looks like im gojng to replace the transmission in my 95 Maxima. As i searched for replavements i see that i have a choice of transmissions with or without a limited slip differrntial. Which do i need? How do i know what tranny is in there now?
The reason im chamging is the transmission shifts real hard between 1st and 2nd gears. Ive had the transmission serviced at the local nissan dealership and that did not solve the problem. Currently the transmission has 215,000 miles on it so im thinking the time is right for a new one.
Old Oct 29, 2017 | 09:58 PM
JvG's Avatar
JvG
In general, the USA got non limited differencials, while Canada got limited slip.
I' can check the Haynes manual for the casting codes if you like.
Old Oct 30, 2017 | 06:08 AM
Trans
that would be great. Thanks for the help.
Old Oct 30, 2017 | 08:12 AM
max ride 41's Avatar
your vin should tell you if you have lsd, or non-lsd in your max
Old Nov 3, 2017 | 04:42 PM
also...i'm seeing transmissions for a 95 Maxima on Ebay for $200 plus shipping. They're used trannys but would that be worth taking a chance on? That seems awful cheap. I looked at rockauto and they have one left for $1500
Old Nov 3, 2017 | 04:50 PM
krismax's Avatar
Father of the 00 VI
you can also use 00-01 trans built better
