Crunchy clutch noise
Since swapping the clutch (pulled the engine) I’ve been getting a really weird cracking sound when I’m coming back off the clutch in gear, especially first.
At about 5 seconds you’ll hear it. Sorry no video it was dark out and I didn’t have a cameraman.
New clutch disk / plate / throwout bearing. It seems especially bad when I’m trying to apply a fair amount of torque on a quick start. Thoughts?
How far does the thrwout bearing travel on the input shaft? I noticed that the input shaft sleeve didn’t have any lubrication on it. Would I even be able to hear the throwout bearing moving back and forth on the sleeve?
Many clutch kits include the grease for this.
I used high temperature wheel bearing grease on a Toyota Corolla clutch I did earlier this year. It works fine.
Axle noise associated with the clutch? It correlates directly with the clutch pedal being lifted and torque being applied.
My axles were replaced in February and I'm sure they seated correctly when we put them back in, but it's worth a check.
Seems like my passenger side axle has a bad CV joint :P They're remanned A-1 Cardone's and I hear this happens. I may just end up rebuilding the joint, the boot is fine.
![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
I'm wondering specifically if the inner diameter of the throwout bearing should have been greased where it rides on the input shaft sleeve (I'm assuming that's what it rides on...). I looked at it, asked my friend if that gets greased and he said that it doesn't usually.
I may take the car back by his place and have him give it a once over. With my move looming I'm not sure I have the time to drop the transmission again. We'll see! Might be worth it...
Just to follow up on this... After about 2500 miles this noise went away. I think it was something to do with the new throwout bearing or clutch plate getting properly seated. No more crunchy clutch noise and no intervention from myself.
Thank you for reporting your sucessful outcome.
