removing dash kits
Old Feb 2, 2002 | 09:36 AM
Aziantank88's Avatar
removing dash kits
i have a wood dash kit now and i was wondering how hard it would be to replace itwith a different one
Old Feb 2, 2002 | 09:37 AM
redmaxpa007's Avatar
i SeE what you did therE
Re: removing dash kits
just use a hair dryer or heat gun and heat up the stuff and pull....
Old Feb 2, 2002 | 11:51 AM
TintDaMax's Avatar
Re: Re: removing dash kits
Yeah, but just remember that if you do that, you cant use it again
DPW
Old Feb 2, 2002 | 12:03 PM
1MAX2NV's Avatar
It's a lot work
I would use a heat gun. It will take forever with a hairdyer. The hardest part is cleaning all those residue. You could buy one of those rubber wheels at body shop supply store that are used to remove pinstrips. If not, it's alot of rubbing with your finger tips with goo off.
Old Feb 2, 2002 | 12:09 PM
Re: Re: Re: removing dash kits
DPW
true..true
Old Feb 2, 2002 | 01:55 PM
1MAX2NV's Avatar
No one will buy a used dash kit. After reapplying all those 3M tapes, it might cost as much as a new kit.
DPW
Old Feb 2, 2002 | 03:07 PM
Nismo82's Avatar
Yeah, I can't imagine if you'd resell the kit (if that what you plan) Mine didn't seem very reusable (I also ripped pieces)
It's a biatch getting all the stuff (old adhesive) off, I had the bruised fingers and bloody nails to prove it. Rubbing alcohol helps get it off and preps it for the new adhesive. It lightened up the plastic under though, but if you are putting it over anyway, it shouldn't really bother anything. It took a while and I had my girl workin, Workin, WORKIN'! (If I only had one of those "rubber thingies" 1max2nv is talkin about...)
Old Feb 2, 2002 | 03:10 PM
i just took off two pieces so i can get new ones installed and they were a BIAtch to take off..
Old Feb 2, 2002 | 06:38 PM
WizzaMax's Avatar
Slip strand of fishing line or dental floss under edge (wear leather gloves) and work it back and forth til the piece is separated from the dash...should work well for small parts.
Old Feb 2, 2002 | 08:02 PM
1MAX2NV's Avatar
The rubber wheel thingy I'm talking works like a giant eraser. It basically attached to a drill and you can put it up againest all those old adhesive. It should spin off all those junk. I said it should because I saw the product after I already put on the new kit.
Old Feb 2, 2002 | 11:53 PM
SuDZ's Avatar
Shave it like ya would your emblems on the trunk.
SuDZ
Old Feb 3, 2002 | 03:24 AM
SuDZ
i used the heat gun and the pieces came off, and there was no adhesive left on the dash...
so as soon as my new pieces come in.. i can install them...
The Frye
Sep 2, 2021 11:03 AM
Kingofmaximas24
Nov 12, 2015 04:40 PM
BrandonCause
Sep 20, 2015 10:20 PM
