97 Sputter and Die on hard accel (P1447,0100,0400)
Old Mar 4, 2018 | 01:33 PM
turbochamp's Avatar
I was gifted a 97 Maxima that needs a little work. It drives, but on hard acceleration she will sputter and then die. It'll restart just fine with a little gas. I took it to Autozone to get the codes ran and I have P1447, P0100, P0400.
The person who gave it to me says it'll the catalyic converter but I rather try cleaning or replacing smaller things before getting to that. Suggestions on where to start?
Old Mar 4, 2018 | 04:15 PM
CS_AR's Avatar
Looks like you need a good mid-life service.
P1447 - Evap System - Check to see if the canister is leaking charcoal into the evap system.
P0400 - EGR tube most likely clogged. Check out how to clean and gasket the EGR system.
P0100 - Mass Air Flow.
Old Mar 4, 2018 | 11:16 PM
Maxima 97 SE's Avatar
If you are gifted the car and plan on keeping it for a long time, then buy an oem original nissan mass air flow sensor from amazon. You will be trouble free for a long time. I did the same for my maxima. heres the link for the sensor
Amazon Amazon
Old Mar 5, 2018 | 01:23 AM
max ride 41's Avatar
go to a junkyard and find an oem one off of a lower mileage motor if possible. aftermarket ones are touch and go.
Old Mar 5, 2018 | 10:01 AM
Do this first. Then buy a new one if you cant find one.
Maxima99SE
Feb 17, 2006 09:58 PM
albertma
Feb 1, 2005 10:34 PM
hfranciss
Nov 1, 2003 04:17 PM
tkarrh
Jun 25, 2003 05:47 AM
