Bulk hose ID to replace Power Steering Suction Hose
Old Mar 22, 2018 | 10:19 AM
marianm's Avatar
I'm talking about the molded hose that connects the power steering reservoir to the power steering pump. Has anyone replaced it with bulk ATF/PS hose? What inside diameter did you use? I've seen 5/8 mentioned as a possibility.
Old Mar 22, 2018 | 12:06 PM
schmellyfart's Avatar
I've done it before, but the hose ended up getting a kink in it after a while. I replaced it with an OEM Hose and am much happier with it. https://www.nissanpartsdeal.com/part...piping,,49717M
Old Mar 22, 2018 | 12:43 PM
marianm's Avatar
hose
Thanks for the reply!
What ID was the hose though? Was it a heavy duty type of hose, or a thin walled hose?
Old Mar 22, 2018 | 05:30 PM
I couldn't tell ya the size, it was over 5 years ago. They didn't have one that was an exact fit, I had to crank down on the hose clamp to seal it. And the one I used was rated for use in fuel/evap systems.
Old Mar 26, 2018 | 07:37 AM
marianm's Avatar
hose ID
Thanks!
I measured the reservoir spigot diameter at 16.7 mm so a 5/8 hose should work.
If I had the hose off the car I could take it to a part store and try to find a similarly prebent hose that could be trimmed, depending on the skill of the parts dude.
Old Jun 20, 2018 | 03:22 PM
marianm's Avatar
I ended up using this bulk PS return hose I found at Napa. 5/8" was not tight, but at least it was easy to connect to the PS pump in that tight location. I reused the OE clamps, 2 months and 3k miles later all good no leaks. Since it's not molded, I added a piece of split hose to protect it from rubbing the timing cover.
iTzCloud
Apr 9, 2016 08:06 PM
Starrider
Jun 5, 2015 06:44 PM
charlie954
Feb 14, 2015 01:42 PM
OnTheRoad
Nov 9, 2011 11:27 PM
dgeesaman
Jan 11, 2006 08:27 AM
