Body Control Module question
Old Apr 24, 2018 | 12:23 PM
Shannon and Ian's Avatar
My windows and drivers door does not work. The switch is fine. Had to tap fuseblock to get power to the switch now every door and window but the drivers door works. My mechanic checked all the wiring and said the only thing left is the BCM. I am on eBay looking for them and there are some that say no keyless entry and some that do. My questions are 1) where else should i check to diagnose the window/master door lock and 2)don't all Maxims have keyless entry? Thanks.
Old Apr 24, 2018 | 01:46 PM
maximaxi's Avatar
I don't think every 4th gen had keyless entry. Also, don't forget about the I30, which did come standard with keyless.
You can use the keyless entry BCM in cars that didn't come with it.
Old Apr 24, 2018 | 05:26 PM
edwardh1's Avatar
what is keyless entry? using the key fob to unlock the door?
Old Apr 25, 2018 | 05:55 AM
That is what confuses me. I seriously thought all Maximas had this
Old Apr 25, 2018 | 06:24 AM
RA030726's Avatar
I'm nutty for Nissans
Keyless was part of a package option on some models.
For the bcm, what year and options do you have?
Old Apr 25, 2018 | 09:52 AM
DennisMik's Avatar
No, not all maximas came with keyless entry. I worked with a guy in the Seattle Washington area whose car didn't have it and he added it. It was a project.
Maybe the BCM is bad, but it could also be the master power window switch. It could also be a wire harness problem, a broken wire from the door opening and closing.
95 & 96 cars are different than the 97 to 99 cars.
Max96GLE
Aug 23, 2010 09:00 AM
2da mizzax
Jan 5, 2009 11:17 AM
Max96GLE
Nov 11, 2004 06:07 AM
bg18461
Aug 26, 2003 12:41 PM
henock
Jun 21, 2003 06:20 PM
