Would replacing lateral link fix alignment?
Old May 25, 2018 | 11:05 AM
Maxima 97 SE's Avatar
would replacing the rear beam lateral link help with real alignment toe issues? I planned on replacing both the lateral link and control rod. Any suggestions would help. Thank you.
Old May 25, 2018 | 11:21 AM
KP11520's Avatar
The Lateral Link really just helps body roll around turns.
I did both just to refresh them in case the corrosion on the link was approaching compromise or the bushings were shot.
Neither was a problem and no change in anything was netted. Make sure the bushings are OK on the trailing control arms of the axle beam as well.
Unless you have a bent chassis, everything that can affect Toe in is with Tie Rods (power Steering Rack), Strut assemblies and Lower Control Arm assemblies.
Hope this helps.
Old May 25, 2018 | 12:46 PM
thank you, this definitely helps. Good info and I'll look at the trailing control arm bushings.
TunerMaxima3000
Feb 24, 2011 05:35 PM
fithos
Feb 20, 2007 07:41 PM
Wheelie King
Aug 15, 2006 09:45 PM
illtoro
Apr 13, 2005 06:17 PM
nick
Jun 5, 2003 08:24 AM
