Spacer For Front Strut Tower Bar?
Old Jun 6, 2018 | 09:50 AM
Turbobink's Avatar
During the process of, again, rendering a bunch of under-hood stuff "in pieces", I removed my strut tower bar that's probably been installed for the past 5 or 7 years.
Once I removed the passenger side mounting plate, to my horror I saw that the portion of the bracket that over-hangs my low pressure side A/C hose and been in contact with and has been marring the hard-line portion of the A/C hose ... right there:
Anyway, does anyone have any leads on a spacer appropriate for this situation?
Something like this:
Old Jun 6, 2018 | 11:43 AM
schmellyfart's Avatar
Title
I can make something for you. Shoot me a PM or email and we can discuss.
Old Jun 6, 2018 | 12:08 PM
There is supposed to be an OEM bracket on the side of the strut tower which holds the AC line in place, and protects it with a foam/rubber insulator. I think I see it lurking within your red circle. You can loosen the bolt that secures it to the strut tower and slide it down a 1/4" to give the AC line adequate clearance.
Also, the AC line is soft aluminum. Very gently, you can simply bend the AC line just a little and you'll have the adequate clearance to prevent rubbing.
Old Jun 6, 2018 | 06:40 PM
CS_AR's Avatar
^^^ +1
Old Jun 12, 2018 | 09:32 PM
Quickywd01's Avatar
I agree. And you gotta do it when you put the supercharger on.
maxinout93
Jun 25, 2009 08:14 AM
RMAX
Dec 30, 2004 04:54 AM
SupaMaxima
Apr 25, 2002 11:21 AM
maxmonkey
Jun 20, 2001 12:26 PM
