GRound wire on Ypipe bolt by cat, is that for the 02 sensor? or what?
well i was just curious what that metal wire on the cat bolt was, is it for a ground for the o2 sensor?
the reason im asking is because that dam bolt came loose, and i have a crazy leak which i cant fix at the moment. the thing is that wire is disconnected. is it necessary? or what?
It's part of the circuit. The body of the oxygen sensor is the reference used for the signal voltage. Since the exhaust system is hanging by rubber hangers (insulators), the only place it can get back to ground it via the studs going into the manifold. So a direct grounding strap would keep the whole y-pipe assembly at the same exact ground as the ECU.
Dave
Dave
I had no idea what that was, when I had to replace my y pipe and cat converter. Mine was so corroded, I couldn't tell what it was, other than a couple thin pieces of corroded *** wire. I have replaced my O2 sensors, but never replaced that ground wire, and still get around 350 gallons to a tank on avg. I don't think your gas mileage will be affected, if any, without the wire.
As for those running without a ground strap, that's fine too. There will only be a single ground path to ground the sensor, which is fine if that path remains low resistance. The risk (recall I performed a resistance test on mine and found it was not good), is the O2 sensor signal will be off, which could affect the fuel economy. If your existing studs and exhaust haven't rusted the way mine have (I drive a LOT of salty highway miles in winter), and your properly calculated fuel economy is still good, it's entirely reasonable that the strap will always be redundant. YMMV.
I replaced my broken ground strap just last night, so in a couple days I will report if it made any impact on fuel economy. For the few bucks that it costs, you can't argue against the value as cheap insurance.
Dave
Originally Posted by dgeesaman
That's not a measurement of gas mileage. That's a measurement of how low you let your tank get before filling, if it measures anything at all.
Example:
Gas is at close to empty since last fill-up...fill up with 16 gallons and notice the trip odometer shows 350 miles from last fill-up. Then 350/16 would equal ~21mpg.
Originally Posted by MrEous
Incorrect...if you fill up the tank to its fullest, then fill up again when you need gas then you can convert to MPG. You have to use your trip odometer, I figured everyone did this already.
Example:
Example:
Dave
The O2 sensor connector has 4 wires. One of these wires is a chassis ground. So, the O2 sensor is grounded by it's connector. This explains why the braided ground wire if disconnected does not affect anything else. The other the wires of the sensor are: one signal wire , and 2 wires for the heating element within the O2 sensor.
If the O2 sensor was not grounded, the CEL would immediately lit.
hello .. im new to the site plus dont know much about cars .. i have 98 nissan mexima ...recently having a problem which is when i press the gas paddel the ramp gose over 2.8 but the car doesnt seem like picking up the speed like the way im pressing the gas paddel ..its seem like going and then give a kinck and bhom runs allright. its seem like someone puling me from back and then letting it go ..its even bivrate with wired noise +its even give more worse noise + bivrate on reverse gear ..my questions is why its doesnt pick up smoothly? or why the car doesnt run to the minimum speed? what could be the problem and what is the sloution? thanks guys
In any case, like I said the grounding issue is a theory.
Dave
I think you shoulda said it was a theory at the beginning of the thread. Now your posts are gonna be "gospel" to n00bs here who are gonna think the motor's gonna blow up without a ground strap. Truth be told, they're unnecessary.
I quote myself:
And as for it being unnecessary, that's a silly statement. There is no way to inspect the connection from the y-pipe to the chassis ground without a resistance meter. A grounding strap is generally quite reliable with just a visual inspection. So even if it's only a backup, it's a simple and effective backup. In fact, it's easier to just install one the next time you're down there than it is to postulate about it on forums. Or don't, frankly I don't care.
But I will not ignore some forum nerd accusing me of writing things I did not write. Especially when gaps in reading comprehension, common sense, and practicality are showing from your side.
Dave
Your reading comprehension needs work. I never said their motor or sensors would blow up, I have no idea where that came from, and I refuted it.
If that reads to you like "gospel", then arguing would be a waste of time.
Bottom line is this, the ground from the o2's to the heads are sufficient and will ALWAYS be sufficient. I don't quite understand how a rusted exhaust would affect the ground since the crucial area between the y-pipe and exhaust manifold isn't exposed to the elements anyway. Think about that...
I thought my sarcasm was clear.......guess not.
FWIW, I filled up my gas tank today and so far my gas mileage is unchanged. So even though my sensors went from poorly grounded to well grounded, it did not affect fuel economy.
Dave
With such a small voltage output coming from the o2's (1V) a good ground is crucial so if the mileage is unchanged the grounding was sufficient all along. I'd be more concerned about this if i had a WB02 with a 0V-5V output. Even then i think it'd be fine.
Grounding by and bonding
Grounding and bonding by Mike Holts.
this is a book that all electricians go by.
If there is a ground in a specific location and doesnt make sense to the regular joe. Then best believe JOE that it's there for a real reason. Grounds are established to provide a path for a short/fault to return to its source.(emphasis on source). If it doesn't return to its source then it sits on an "open" circuit". Which means that i charges and energizes the conductor. Or device. Or equipment. Potentially damaging it, getting someone hurt or shocked or w.e....
Either way, even though it doesn't appear to do anything or change anything.
These ground straps actually provided the shortest/alternate route needed for the short/fault to return to its source eliminating the energizing/damaging of w.e.
it needs to be there guys. Lol
But hey i Don't know anything more than most of yall. Have a good day and I hope ya read Mike Holts books.(s)
Lol at the 17 year old thread bump for you first post. How in the world did you decide to make this your first post??
For what it's worth, I've always wondered about that strap as well. But I can't imagine Nissan spending money to install them on every car if there wasn't a reason for it. So it was with that in mind that I installed a new one on my car when I was redoing my exhaust, since it probably hasn't had that strap for 15+ years. It cost all of like $1 and took a few minutes.
sdotcarter
09-02-2015 09:53 PM
Justin Kroll
09-02-2015 11:06 AM
