Low compression - Rebuild it?
Old Sep 1, 2018 | 05:17 AM
Cody Wayne's Avatar
Hey everyone the question for today is here a few months ago my maxima development a miss did some testing found a cylinder with substantial less compression then the other five we believe the rings are bad my question is should I rebuild it or scrap it and if I rebuild it how should I rebuild it
Old Sep 1, 2018 | 07:00 AM
RA030726's Avatar
I'm nutty for Nissans
Installing a used engine will be far easier and cheaper. Search car-part.com for an engine near you.
Old Sep 1, 2018 | 09:05 AM
JvG's Avatar
JvG
Your problem is most likely a valve.
Look up how to perform a wet and dry compression test. That will indicate if the if the problem is the ring or the valve.
Still, used engines are easier to install, and probably cheaper than repairing yours. I would buy a lower mileage engine, then reseal the valve covers, install a new water pump, new or rebuilt rear fuel injectors, clean out the egr tube, and any thing else I could think of which can be done much easier when the engine is out of the car, and easy to work on.
Old Sep 10, 2018 | 04:02 AM
Cody Wayne's Avatar
Sorry guys I've been busy but I did do a wet compression test and the compression came up quite a bit my other cylinders were close to each other except the one but a wet test helped and what I gathered if a wet test helps it's usually rings
Old Sep 10, 2018 | 09:24 AM
JvG's Avatar
JvG
Yup, rings.
But, since your have nothing to lose, you might try some chemical treatments which are intended to dissolve deposits on rings and valves.
Sea foam in the oil and gasoline for example.
or Marvel Mystery Oil.
Or harsher methods such as GM cylinder cleaner.
Tell the Chevy parts guy that you want to free your rings by doing an engine soak. They sell the chemical.
Note...... rings can be weak due to wear and tear. Only replacing them will help.
However, ...... some owners doon change oil frequently enough, so the crud in the oil creates deposits which cause rings to stick.
Old Sep 30, 2018 | 06:25 AM
Dhione's Avatar
I got a vq35 from car-part.com and the engine had no compression at all. I took the engine apart and all the rings were stuck in the pistons. Just make sure you buy from a reliable place with a decent warranty. Mine didnt have one.
VEvolution
32
Jan 30, 2012 04:43 PM
cjficklin
Jan 12, 2004 09:47 PM
mcfalcons15
Jun 28, 2003 07:02 AM
surfermax92
Aug 23, 2002 10:22 AM
