Q50 wheels and tires
Old Feb 20, 2019 | 03:12 PM
reallywildstuff's Avatar
https://houston.craigslist.org/wtd/d...808338160.html
What do we think about putting this 225/55-17 wheel/tire combo on a 4th gen with stock ride height ? I presume the bolt pattern is the same...
Currently running 205/65R-15 Bridgestone Turanza Serenity Plus SL x 4.
Old Feb 20, 2019 | 04:14 PM
KP11520's Avatar
You won't know until you try them, if they cause any unwanted clearance problems. You can go to a lower profile tire if too tall. BUT most importantly, the Offset has to match 4th Gen Maxima requitements.
Old Feb 20, 2019 | 04:20 PM
CS_AR's Avatar
I'm running 17" Juke wheels on my 98 model without issue. Though my tires OD are basically the same as stock. It depends on the offset.
Old Feb 21, 2019 | 10:15 AM
Should be fine. Stock wheels are usually weak specs (only 7-7.5" wide and between 40-50 offset).
Old Apr 9, 2019 | 09:14 PM
Badracr1's Avatar
I have 2003 G35 Sport wheels on my 00 I30t with 225/50-17 and 235/50-17. No issues. Offset is a little more to the outside but I like that if fills the fenders more.(First post, btw!)
Maxipals
Tires and Wheels
May 20, 2014 01:06 AM
Peter Taylor
Tires and Wheels
Feb 7, 2005 02:53 PM
rcy
Jan 20, 2004 09:23 AM
