Leaking Radiator Top Tube
Old Mar 30, 2019 | 07:22 AM
wxm's Avatar
wxm
Found a leak on the top tube of the radiator, doesn't look too bad. Does anyone try the epoxy fix? How is it holding up? What product do you recommend? It is an original radiator. but it is small crack. If it is not too expensive. I would prefer try to patch it up...
Old Mar 30, 2019 | 11:03 AM
KP11520's Avatar
Suck it up and buy a new one! Summer is going to be a problem!
If you have a MT, there are some all aluminum radiators that will last a LONG time (usually). If AT, you'll find aluminum and plastic combos. Some are better than the rest.
JvG here has a decent one he used and recommends. Hopefully, he'll stop in.
Old Mar 30, 2019 | 11:20 AM
CS_AR's Avatar
Replacement radiators are too cheap to risk trying to repair an original radiator. Save yourself a headache. There is plenty of replacement experiences on there to draw on.
Old Mar 30, 2019 | 12:05 PM
JvG's Avatar
JvG
Our cars are over 20 years old.
The radiators are failing.
Are you willing to risk your engine and basicly your car because you want to save the 50 to 100 dollars a radiator would cost?
Does your air conditioning still work? It sure is nice to stay cool without worrying about overheating.
Every summer some of our members report overheating, radiator failure far from home, blown head gaskets, etc. Some of them tried to "save" money by doing exactly what you are contempating.
Many of those members end up either junking the Maxima, or replacing the engine. Almost all of their cars might still be on the road if they just spent the 50 to 100 dollars for a new radiator.
I've seen radiators for as little as 40 dollars on ebay.
I'd consider that risky. Better ones sell for 100 or so.
I bought a KoyoRad radiator through a group deal through this forum..it cost 106 dollars a few years ago. The quality is excellent.
You might as well replace the top and bottom radiator hoses while you are in there. The top rad hose is usually the first hose to fail on a hot day. Then someone will have engine failure because they bought a 12 pack of beer instead of a hose.
The radiator is a very important part of your car.
Please don't be foolish. Replace it!!!!
Look at ebay, amazon, rock auto, etc.
Buy one asap while it's still cool. Install it real soon.
Old Mar 30, 2019 | 01:01 PM
CS_AR's Avatar
^^^ This. Don't forget the essential OEM components associated with engine coolant.
OEM thermostat and gasket
OEM radiator cap.
I usually get 5 years of service from an aftermarket radiator that costs in the $100 range.
Old Mar 31, 2019 | 08:20 AM
wxm's Avatar
wxm
Thanks Guys, Guess I will be shopping for a new rad. Anyone has experience on the Denso one? I have been using many parts from them on my Toyota and they seem to be pretty good.
Old Mar 31, 2019 | 09:53 AM
JvG's Avatar
JvG
Denso is good. I bought one for my Toyota Corolla when I rebuilt the engine. The original one was also Denso. It was still good after 15 years. I replaced it because I found a new one for 35 dollars on amazon.
Old Apr 1, 2019 | 06:54 AM
M in KC's Avatar
Rad R&R on these cars is a 30 minute job. You are making the best decision to buy new. Denso makes top-shelf products you will be fine there. That is what I replaced mine with a couple years back, no issues.
Old Apr 1, 2019 | 12:57 PM
maximaxi's Avatar
20 years is not bad for an original radiator!
I recommend Denso radiator. I have a Denso on my car, and it is holding up good! The new radiator does not come with a cap, so I got an OEM cap from the dealer for about $20
Old Apr 1, 2019 | 01:56 PM
PH98I30's Avatar
Be sure you get a good radiator cap. With a new radiator, problems start with a crappy cap. Don't go cheap.
2k0to2k3
Dec 8, 2009 01:50 PM
J_Swaleh
23
Aug 14, 2008 01:28 PM
Sounbwoy
Dec 24, 2006 02:48 PM
Cashj2002
Jun 30, 2006 10:51 AM
markmaxima
Oct 3, 2001 01:49 PM
