Oil Leak
Old Jun 12, 2019 | 07:20 PM
blakkrob's Avatar
Oil Leak
I have an oil leak along the fire wall thats leaking on my exhaust manifold. I have changed the Valve cover gaskets so idk where else it coukd be coming from.
Old Jun 12, 2019 | 07:39 PM
reallywildstuff's Avatar
It'd be swell if it was just the oil pressure sender fitting leaking...but it's probably not.
Has the Upper Oil Pan ever been serviced? My '98's never has, and its UOP leaks like a champ...
Old Jun 12, 2019 | 07:44 PM
blakkrob's Avatar
Forgot to mention Sending unit was changed. UOP hasnt been touched, so thats a possibilty
Old Jun 14, 2019 | 12:43 PM
PH98I30's Avatar
That's where mine is leaking. Is the oil dripping around the oil filter and crankshaft sensor?
Old Jun 14, 2019 | 03:01 PM
KP11520's Avatar
Are you sure that's not your front main seal? It's hard to tell with all the oil blowing everywhere as we drive
Old Jun 14, 2019 | 05:17 PM
But did you change them properly, put RTV in the corners per the FSM, and torque everything to spec and in the correct sequence?
MAXiPAD72O
55
Nov 27, 2011 10:42 AM
StylinzMax
Sep 1, 2011 12:03 PM
J_Swaleh
21
Mar 15, 2009 07:46 PM
blackse92
Apr 25, 2005 08:51 PM
maxsthebest
Feb 17, 2004 09:39 AM
