I have a small oil leak, where from?
Old Feb 17, 2004 | 06:12 AM
maxsthebest's Avatar
I have noticed a minor oil leak coming from right above or near the oil filter area. I tried looking up in there to see where it is coming from but I cannot detect it.
Any ideas where this leak could be coming from? And what would be a typical cost to get it repaired? Is there an additive that I can add to the oil to seal it from within?
Old Feb 17, 2004 | 06:33 AM
knight71's Avatar
It could be the oil pressure switch..easy to replace and cheap
check this:
http://www.motorvate.ca/mvp.php/514
Old Feb 17, 2004 | 06:40 AM
LudeAEM's Avatar
I have the exact same thing man. I replaced the oil sender unit... wasn't it. Then I thought i didn't tighten the oil filter down enough. NOt it either. But when I went to go get my transmission serviced I asked if they could see where the leak is coming from. They said its a seal around the timing cover. Like a gasket or something. I don't really know how involved it is but I am not going to mess with it. At least not for now.
Old Feb 17, 2004 | 07:11 AM
95MaxSE's Avatar
Most likely, it's the oil pressure switch. Very easy to replace. The part cost $5.99 at AutoZone. And you'll need a very deep 27mm socket.
Sam
Old Feb 17, 2004 | 08:30 AM
You guys are awesome! That's why I love this board. I am glad I asked about this before taking it to a mechanic and getting ripped off.
Thanks again!
Old Feb 17, 2004 | 09:13 AM
soulrupture's Avatar
I had the same problem and thought it was the oil sensor. It wasn't it was my steering pump. Had to get it replaced. Check your pump first.
Old Feb 17, 2004 | 09:39 AM
techie's Avatar
I hate to say it but, if it's your seals behind the timing cover, that's over a grand to have fixed by someone like a dealer. Make sure you check to see if that's really it.
foodmanry
Sep 24, 2015 12:02 PM
JoshG
51
Sep 21, 2015 10:41 PM
RWCreative
Sep 21, 2015 11:01 AM
pears
Sep 18, 2015 05:25 AM
ag90fox
Sep 9, 2015 12:22 PM
