A random spring fell out of my 5 speed transaxel
Sep 25, 2019 | 12:59 PM
While replacing my clutch. I was lowering the transaxel with a jack... and this small spring appeared on the ground. I wasn't able to see where it came from (inside transaxel...or outside)
The last picture shows where I found it after dropping the transaxel.
Any suggestions? Part of me wonders if the spring is not associated with my current project and had fallen down in the engine awhile ago...
Thanks!
Thanks,
Graham
Sep 25, 2019 | 01:01 PM
How did you drain the fluid?
Sep 25, 2019 | 01:53 PM
Out of the reverse neutral sensor
Quote: How did you drain the fluid?
I drained it out of the reverse/neutral sensor.(I think that’s the sensor). It the big 40mm hole on the bottom.
thanks!
Sep 25, 2019 | 02:33 PM
Did it come from that? I haven't played with that thing because they alway break.
The 12mm drain plug is a pain to use but it's the safest way. I had to grind a wrench to fit in there.
Sep 25, 2019 | 02:37 PM
Looks pretty heavy duty to me, have any idea as to where it came from?
Sep 25, 2019 | 02:39 PM
Isn't it actually a transaxle - not a transaxle?
Anyway I was thinking the sroing may have been part of the clutch disc or the fork ??
Sep 25, 2019 | 02:40 PM
Sorry, should have read spring not sproing...!
Sep 25, 2019 | 03:13 PM
I think it is a detent spring
After reading around the forum, it sounds like it is a detent spring. There should be a ball bearing that goes with it as well. I will search for that once I get back home.
I must have unscrewed a wrong bolt possibly near the gear selector.
Does anyone know if the ball goes in first or the spring goes in first?
Sep 25, 2019 | 03:41 PM
I was thinking a detent spring too. The ones I know about are for the gears. The ball bearing goes in then the spring. Did you unscrew something with a flat head screwdriver?
Sep 25, 2019 | 04:10 PM
Not
I didn’t removing anything with a flathead on it.
I am still trying to locate where it came from. So strange.
Thanks again!
Sep 25, 2019 | 04:59 PM
Diagram
Just found this diagram of the detent springs from the 1996 FSM
