Starting issue
Old Feb 12, 2020 | 06:42 PM
Angel Ortiz's Avatar
Starting issue
Hey can someone maybe give me a hand. My 99 maxima is having a starting issue. The motor is just running sounds like it’s not engaging. Took the starter out then I benched tested it and it works fine but when I installed it back into the vehicle it sounded like the solenoid was not engaging the starter. Took the starter out got a new one just for the hell of it since I had it on warranty but then I still had the same issue. Check the voltage going to the starter and solenoid and everything seems like it’s correct but still sounds like the solenoid was not engaging and the motor is just running. Looked at the fly wheel and the teeth looked fine with no breaks or cracks. Then I bench tested the starter multiple times worked fine now I’m feeling like it’s engaging and just spinning the motor but not making contact with the fly wheel. Rotated the fly wheel by hand everything seems OK but still can’t find the issue. Hopefully someone can help me out here.
Old Feb 13, 2020 | 04:56 PM
DennisMik's Avatar
When you were bench testing the starters, did you notice if the starter gear was thrusting out from the starter?
A possible problem could be that the starter is not aligned properly. If the starter were to somehow be angled, the starter gear would miss the flywheel.
Old Feb 16, 2020 | 09:02 AM
I didn’t notice anything like that happening with either of the two new starters that I tried.
Old Feb 16, 2020 | 11:41 AM
JvG's Avatar
JvG
1. Set park brake and put car in neutral.
2. Put a screwdriver on the small wire and the top large nut.
The starter should spin. It should turn the engineas well.
Tell us what happens.
Old Feb 16, 2020 | 12:46 PM
I already bypass ignition system. I put power directly to the solenoid and starter motor sounded like the solenoid engaged and then the starter motor was just running but wasn’t cranking the engine over
Old Feb 16, 2020 | 01:59 PM
JvG's Avatar
JvG
I would remove the starter.
I'd take it back to the parts store to have them test it.
it's possible that they sold you a defective starter.
It happens.
wxm
Apr 1, 2018 06:59 PM
Nate Boslet
Dec 19, 2017 02:26 AM
Eddiecurbside
Apr 15, 2014 04:28 AM
danno6886
Feb 25, 2014 08:13 PM
Gary95
Nov 9, 2003 12:03 PM
