02 Sensor Woes
Old Oct 17, 2020 | 10:21 AM
ilyaa's Avatar
02 Sensor Woes
hey all!
trying to lay this issue to bed once and for all
99 Cali Spec Maxima
i was getting these codes
P1168 (closed loop control function bank 2)
P0150 (bank 2 sensor 1 malfunction)
so i
cleaned the MAF sensor
changed the 02 sensor fuse
changed the bank 2 sensor 1 02 sensor
now i get a
P0154 (bank 2 sensor 1 no activity detected)
there are no noticeable symptoms except that if it's sat a few days, the car often takes 2 attempts to start. it cranks but doesnt turn over. if i try again it turns over just fine.
what might be the issue? vacuum leak? the wiring looks fine but i am not sure how to check it all the way back to the module - at any rate, doesnt seem likely the wiring got damaged upstream.
any thoughts?
Old Oct 18, 2020 | 03:14 AM
Rit's Avatar
Rit
When you say cranks but doesn't turn over, are you saying that the starter motor spins the engine but it doesn't start running ?
Old Oct 18, 2020 | 09:41 AM
ilyaa's Avatar
yes - i turn the key, the starter spins the engine and it cranks, but doesnt start running. i turn it all off and turn the ignition again and it starts up just fine. that usually happens when the car has been sitting a while -
Old Oct 19, 2020 | 04:21 AM
Rit's Avatar
Rit
What if you just turn the key to on for about 5 seconds, not start, and let the fuel pump pressurize the fuel lines, and then try to start it. Does it start first time ?
Old Nov 8, 2020 | 09:43 PM
ilyaa's Avatar
ya that seems to do it MOST of the time - but occasionally it still needs two cranks....
and mostly i am just frustrated the CEL is still on, even though i changed the O2 sensor -
what else should i try??
DukeLeto2
Mar 9, 2015 07:12 AM
maximaman10
Feb 15, 2005 06:38 PM
minsbang
Apr 8, 2004 11:35 PM
