Oil change - how often?!
Old Nov 14, 2000 | 08:23 PM
Max30GV
HI,
As I have seen in your discussions you change oil (even Amsoil) every 5-8k miles. But I have an info from Amsoil that oil has to be changed every 12mth/62000k... Are they wrong? Do you have a reason to change it more frequent then manufacture recommends?
Old Nov 14, 2000 | 09:27 PM
Surge Diesal
Where U live?
Every 3K to be ****.
Every 5K to be safe.
Anything more and the oil gets too grimy.
I've been using CASTROL GTX since I got the ride what does everyone else like?
Old Nov 14, 2000 | 11:32 PM
Maxima97GLE's Avatar
I change my oil every 3,000 miles but thats cuz I like to hit the gas on the highway and on the strip. I drive a lot and I'll only drive my Maxine. I only use Mobil 1 Synthetic
10w-30.
Old Nov 15, 2000 | 02:04 AM
turbolaw99's Avatar
The best non-synthetic oil? The shop I go to recommends Castrol GTX every 3K. Make sure you use an OEM filter, though.
Old Nov 15, 2000 | 02:32 AM
Kenneth's Avatar
OG :)
valvoline, imo
every 3-7.5k here.
Old Nov 15, 2000 | 06:48 AM
Shingles's Avatar
The missing moderator
Re: Where U live?
False... if you use true synthetics such as Mobile 1, I have documented lab reports that I did myself that proves at 7500 miles, the oil is still fine. See my sig. And even if you use regular oil, if you look carefully in your owners manual, 7500 is in there as a "normal" driving condition... but I think you are right in that with dino oil, 5000 is probably the most I'd go with.
-Shing
[Edited by Shingles on 11-15-2000 at 08:50 AM]
Old Nov 15, 2000 | 06:58 AM
JacksMax's Avatar
Haynes manual
Originally posted by Max30GV
HI,
My Haynes manual says to change it every 3 mo or 3000 miles. Sounds too **** to me. My owners manual tells all about changing oil EXCEPT for how often to do it.
I plan to use Valvoline 5W30. [I just got the car in Oct.] Maybe 3-5000 miles. I do a lot of short trips, so its probably getting dirty do so many warmups making it need to be changed more often.
Both the Haynes and the owners manual say to use 5W30, does 10W30 do any harm except making it harder to crank in cold weather?
Jack
Old Nov 15, 2000 | 08:50 AM
humaras's Avatar
short trips
well, for me to drive 5K would probably be 6-8 months --in that span of time, most of the trips are about 3 miles round trip...and I am using mobil 1 synthetic...but I would say a good measure is twice a year (with what I am doing) which is far from being ****--and wouldn't cost an arm or leg.
Old Nov 15, 2000 | 09:34 AM
Shingles's Avatar
Re: short trips
Man, must be nice to only drive 5k every 6 months.
-Shing
Old Nov 15, 2000 | 10:14 AM
JacksMax's Avatar
5000 miles....
-Shing [/I]
I put on 5K a year myself.
Jack
Old Nov 15, 2000 | 10:26 AM
humaras's Avatar
Re: 5000 miles....
5k a year--that is something--so you change your oil once a year if you are using synthetic?
-Shing
Jack [/I]
Old Nov 15, 2000 | 11:12 AM
I put a good 2-4 thousand miles a month. But thats because I live on Long Isnad, NY and go to school near Newark, NJ. Plus I work and I go out at night.
Old Nov 15, 2000 | 12:02 PM
JacksMax's Avatar
Re: Re: 5000 miles....
[/I][/QUOTE]
I just got the car this Oct. I plan to change it every 3000.
Jack
Old Nov 15, 2000 | 01:31 PM
Mikeb120's Avatar
IT really depends where you live and the climate.
If you live in lets say NYC, where it gets cold and you do alot of city driving then i think 3k is good.
Other wise you could just go with 5k.
Personally, I am still searching for a Maxima SE but I currently change my oil every 3k miles in my 94 Caprice SS
(Police Pkg, impala clone w/lt1). I do this even though i live in the suburbs of Maryland and have all my miles on the hwy. All the guys i know that own Trans AMs, Z28s or Impalas do the same. Just my 2cents.
I think its a common consesus that people belive 3-5 is good.
(i have no idea about synthetic...i never changed to synthetic since I was told that once you start you can never go back to reg)
Mike
94 9c1/SS
trying to find a Maxima SE....
Old Nov 15, 2000 | 01:47 PM
Max30GV
Re: Re: Where U live?
-Shing
Shing,
I really trust your test results! But - you have tested Mobil 'One'. Amsoil "recommends" to change it's oil - (depends on type) - some every 6 mth/30000km, some - every 12 mth/62000km. Amsoil's dealer recommended me to change 12mth/40000km, but this still is too far from 5-7000 for other brands. Have you tested other brands, and - (if yes) - have you seen much differences? It looks like Amsoil last longer then other brands. I do not drive a lot my Maxima (this is our second car), but I like it so much, and want use realy good oil. Mobil 1 and Amsoil (probably) are best, but I will switch to Amsoil as it needs less chahges without quality pooring... What do you think?
Thank in advance
Old Nov 15, 2000 | 02:05 PM
Shingles's Avatar
Re: Re: Re: Where U live?
I used Mobile 1 synthetic 5W-30. Amsoil is a better oil... They even warranty your engine if you follow their directions... ie change filter ever x miles. So I would say that it would be fine.
BTW to clarify I use nissan OEM filters.
-Shing
-Shing
Shing,
Thank in advance
Old Nov 15, 2000 | 05:33 PM
Surge Diesal
I've put on 65000 miles in under two years giving me an oil change once every month or so. I'm getting rid of my car soon to move up to a 99 with less miles.
Old Nov 15, 2000 | 06:15 PM
humaras's Avatar
65000 in 2 years?
those are some incredible driving--
I don't think I have driven 65K in the 6 years I have had my drivers license...
55k maybe if I count every mile driven.
wow...
Old Nov 15, 2000 | 07:05 PM
party_boy's Avatar
hmmm
ok 2 facts
1. oil breaks down (oxidation)
2. oil collects debris (water, dirt, metal shavings etc.
My personal habits
1. change oil every 5k (i use dino its clear mostly) its easy to remember. every 5 and 0 in the thousands =)
2. For whoever said they drove 5k in a year. your oil breaks down in time. i;d personally change 6 months. also if you have your motor sit too long. it will sieze. try to drive 15-20 min every other week...just my .02
then again the second doesn't affect me i drive ~40k year on the max...and to think the max isnt even the commuter!
Old Nov 15, 2000 | 07:06 PM
Shingles's Avatar
Re: 65000 in 2 years?
wow...
Hehe... I think 8 years I've been driving... I've driven...
20k first car
135k second car
57K in maxima( 2 years 2 months old)
18k in CRX (owned 1 year)
hehe.
-Shing
JoshG
51
Sep 21, 2015 10:41 PM
f.matejaiii
Sep 21, 2015 12:09 PM
97_GXE
20
Sep 17, 2015 08:12 PM
ag90fox
Sep 9, 2015 12:22 PM
sdotcarter
Sep 2, 2015 09:53 PM
