12v power outlet
Old Jan 11, 2021 | 01:00 AM
jack818's Avatar
12v power outlet
how many 12v power outlets does 1995 maxima have?
how to remove the cig socket? thanks!
Old Jan 11, 2021 | 03:03 AM
Rit's Avatar
Rit
One, the cig socket. Download a copy of the FSM for procedure to remove it.
Old Jan 11, 2021 | 08:40 PM
jack818's Avatar
thanks for help, what is FSM ?
Old Jan 11, 2021 | 09:36 PM
FSM=Factory Service Manual
Free download, see my signature
Old Jan 11, 2021 | 10:29 PM
jack818's Avatar
thanks !
Old Jan 12, 2021 | 07:04 PM
komik's Avatar
Hey Jack, what are you doing with the 12 volt power? It sounds like you're looking to add / install something. Maybe we can offer some other suggestions.
Old Jan 12, 2021 | 07:19 PM
jack818's Avatar
Hi Komik, my cig socket not working, the fuse is good, i need fix it. thanks!
Old Jan 19, 2021 | 06:59 AM
Maximus10's Avatar
12v
That's exactly what I used after my Max was stolen.. they got the fog lights.. So I installed new fogs in the front holes with the switch in 12v since I barely ever used it
Old Jan 19, 2021 | 08:40 PM
komik's Avatar
If the fuse is good, but the socket isn't working, there is either dirt / corrosion in the base of the socket, or the device you're plugging into it may have a blown fuse.
The socket is attached to the trim panel around the shifter. In my manual transmission Maxima, the trim panel is removed by gently pulling around the edges. If you have an auto, you may need something (like a flat screwdriver wrapped in a cloth rag) to pry up around the edges of the trim panel. There is a shroud around the socket that unscrews from the back. Once that is removed and you unplug the harness, the socket slides out the front of the trim panel.
You should be able to get a generic replacement at an auto parts store that will plug right in to the factory harness. If you're only looking to charge a phone, you may be able to find a USB style replacement socket that you can wire in place of the original cigarette lighter.
Old Jan 19, 2021 | 08:59 PM
jack818's Avatar
thanks a lot! I have fixed it, thanks again.
Old Jan 19, 2021 | 10:59 PM
Care to tell us how you fixed it?
Old Jan 19, 2021 | 11:38 PM
jack818's Avatar
it just because the wire connector to the socket come off from the socket, it is somewhat strange how could it happened like that. thanks for help!
hellochen
Jul 31, 2004 10:01 PM
Paul Koenning
Apr 24, 2003 05:41 PM
