Corner Light
Old Jan 18, 2021 | 09:47 PM
jack818's Avatar
Corner Light
hi, does any body know 99 maxima Corner Light fit to 95 maxima or not? thanks!
Old Jan 18, 2021 | 10:19 PM
Yes, will fit just fine.
Old Jan 18, 2021 | 11:42 PM
jack818's Avatar
thanks!
Old Jan 19, 2021 | 08:58 AM
jack818's Avatar
hi, why I see in some pictures the 95 corner light has three wire prongs in the connection socket, but the 99 corner light has only two prongs? you can see in the following pictures, thanks!
Old Jan 19, 2021 | 05:49 PM
Maximus10's Avatar
I just didn't know that
Old Jan 19, 2021 | 06:21 PM
Looks like 95 and 96 may have the same connections, and 97-99 have the same connections. The corner light is still compatible for all years if you swap out the attached harness. Problem solved. The part where the bulb is, is the same; so swapping harnesses is easy and doable.
Old Jan 19, 2021 | 06:47 PM
jack818's Avatar
thank you very much! but the harnesses is what i need, my bulb and the lenses is still good, only the plastic harnesses is broken. thanks again!
Old Jan 19, 2021 | 06:49 PM
Have you popped off your corner light to confirm how many prongs are in your connector?
Old Jan 19, 2021 | 07:08 PM
jack818's Avatar
sorry, my English is not good, which part is the harnesses? do you mean the bulb socket? my broken part is right on the top little plastic stick with a whole screwed to the car.
Old Jan 19, 2021 | 07:19 PM
jack818's Avatar
not yet,
Old Jan 19, 2021 | 09:14 PM
komik's Avatar
Jack818, is this the part that is broken? Mine is broken, put together with JB Weld, and held on to the car with a zip tie instead of a screw.
If your bulb, socket, and wires are still good, you should be able to replace the lens assembly with any one from 95-99 and the bulb should still fit.
Old Jan 19, 2021 | 09:35 PM
jack818's Avatar
thanks, my problem is almost the same as yours, just the position is a little different, I will try to fix it like your way, thanks again! JB Weld is the strongest glue?
Old Jan 19, 2021 | 10:57 PM
So your harness is messed up, and you have a broken tab which helps mount the light to the chassis? So two issues?
Old Jan 19, 2021 | 11:44 PM
jack818's Avatar
one issue, only broken tab, my English is not good, I do not know the English name for each part, sorry about that, thanks for all the help!
Old Jan 20, 2021 | 05:31 PM
Time is money. At $14 shipped, why not simply buy a new corner light and install it rather than reconstructing or fixing the broken tab? Swapping the harness only take a minute.
https://www.ebay.com/itm/Front-Park-...90c5%7Ciid%3A1
A new pair is $26
https://www.ebay.com/itm/Park-Turn-S....c100005.m1851
Old Jan 20, 2021 | 06:50 PM
jack818's Avatar
today I check the corner light, it is easy to swap the harness, I will buy a new one, thanks !
Old Jan 20, 2021 | 07:14 PM
jack818's Avatar
do you know what hold the metal snub on the bottom of the corner light? my snub is very loose, feels like no any function. thanks!
Old Jan 20, 2021 | 08:11 PM
That metal protrusion is supposed to go into a rubber grommet attached to the headlight once installed. The rubber grommets dries out and become brittle over time.
See picture 9 in the listing below for the little pale white grommet that I'm referring to
https://www.ebay.com/itm/Headlight-S...Cclp%3A2334524
Old Jan 20, 2021 | 08:16 PM
Your local auto parts store may have generic grommets for you to choose from. Find the closest size. If all else fails, I've seen people wrap the metal protrusion with duct tape (duck tape). Do this by trial and error until you get just the right amount of tape so that it's a nice snug fit.
Old Jan 20, 2021 | 08:23 PM
jack818's Avatar
I really appreciate your help, thanks!
Old Jan 21, 2021 | 01:21 AM
jack818's Avatar
grommet
do you know which shape of the following two grommet is good? thanks!
Old Jan 21, 2021 | 10:43 AM
The first picture
Old Jan 21, 2021 | 07:37 PM
jack818's Avatar
thanks!
Old Jan 22, 2021 | 09:14 AM
RA030726's Avatar
I'm nutty for Nissans
95 and 96 have 3 wires because when the turn signal is on the corner light gets brighter illuminating more road/sidewalk/curb when taking corners.
97-99 don't.
Old Jan 22, 2021 | 07:24 PM
jack818's Avatar
thanks!
jeffsui
Nov 29, 2023 08:53 PM
s0ber
Jun 4, 2003 05:01 PM
gtr19
Oct 14, 2002 10:36 PM
