Oxygen sensor removal.
Old Apr 11, 2021 | 02:15 PM
intimidator's Avatar
I am trying to replace bank 2 sensor 1 oxygen sensor the one in front of the radiator. I am using the oxygen sensor removal tool but there no room to fit a rachet to turn the tool.
Old Apr 11, 2021 | 03:33 PM
JvG's Avatar
JvG
Been a while since I've done one.
As I recall, I attached an extention between the socket and the wrench.
You should have several extention's available when working on this car. 3 inch, 6 inch, 12 inch. You might want put a couple together for still longer reach.
You might also want to consider finding a cheater pipe.
Old Apr 11, 2021 | 04:09 PM
maxima297's Avatar
Def recommend extensions so you can go over the crossmember. An open ended wrench may also work.
Old Apr 11, 2021 | 05:49 PM
RA030726's Avatar
I'm nutty for Nissans
If the old one is junk, cut the wires and use the closed end of a 22mm wrench.
Alternatively, find a different style O2 tool.
Old Apr 11, 2021 | 06:11 PM
I was trying to attach an extension from the front. The lip of the heat shield is blocking me from attaching the extension.
Old Apr 11, 2021 | 08:03 PM
JvG's Avatar
JvG
Looks like you need to get under the car to do this.
Old Apr 19, 2021 | 02:24 PM
98maxBK's Avatar
Did this recently. Done from under the car, there is some space after removing the plastic splash guards. PB blaster and breaker bar required. If its the original sensor/ been on there a while you will most likely break your ratchet trying to remove it, so use the breaker bar. It may be a touch easier if you do it after driving, but try not to burn yourself. Torch is always the last resort, but it's sometimes needed with bolts that wont budge.
Old Apr 24, 2021 | 12:55 PM
Thanks for everyone help. Starting the engine heating up the sensor helped.
Old Apr 24, 2021 | 11:34 PM
max ride 41's Avatar
no need to start 2 threads for the same issue.
boondoxmax
Mar 20, 2014 07:00 PM
blinelaxd27
Aug 18, 2011 01:01 PM
