P0150 replaced sensor problem.
Old Apr 24, 2021 | 12:57 PM
intimidator's Avatar
I am getting p0150 code. I replaced the oxygen sensor and the code is still coming up.
Old Apr 24, 2021 | 11:31 PM
max ride 41's Avatar
so you did sensor 1 bank 2? verify that you cleared code after replacing.
Old Apr 24, 2021 | 11:34 PM
I replaced bank 2 sensor 1 and then cleared the code.
Old Apr 25, 2021 | 06:12 AM
might have got a bad one out of the box. check to make sure that it plugged in all the way, maybe even unplug to make sure. it might be the other 02 sensor reading bad now.
Old Apr 25, 2021 | 08:08 AM
KP11520's Avatar
If you can get at the plug, scrape the contacts with a screwdriver or box cutter to make sure there's no corrosion in the way. Also follow the wires up looking for any damage.
Just another possibility. Hope you used NGK/NTK.
Old Apr 25, 2021 | 09:59 AM
I bought a Bosch oxygen sensor.
car5car
Jun 24, 2018 05:44 PM
yankeefan13
Mar 6, 2011 07:37 PM
malumax
Sep 23, 2003 12:52 PM
