clattering noise in engine when cold
It does not clatter at idle, but once you start driving, there is a clattering sound, not very loud. It used to always go away once engine warmed up, but lately it seems to only reduce. The clatter seems to be associated with how much you press the gas petal, and not RPM. So if you lightly press gas on a warm engine, you won't hear it even if RPM climbs. It's not associated with how fast the wheels are spinning, that's for sure though.
Is the clatter more noticeable when the engine is under load, like going up a hill.
Is your car auto or stick
What is the oil level
What weight oil is in the engine
How many miles are on the engine
Auto transmission.
Oil level is normal (half way between L and H.
I use 10w30 Mobil 1 full synthetic.
Engine is 136K miles.
Drive up the hill in your normal gear.
Shift to a lower gear and climb the same hill at the same speed.
Does the clatter seem faster?
If so, the clatter is probably caused by the engine.
Do you use regular gasoline, or or premium?
I will try the uphill thing you mentioned.
jasonmax
Dec 30, 2007 01:57 PM
Whtmax'01
Oct 16, 2004 11:28 PM
