PROBLEMS starting
Old Feb 7, 2002 | 07:30 PM
poolstick01's Avatar
PROBLEMS starting
Ok, when I start my car in the morning, it makes a weird noise (which is coming from the starter), then it dies. Only way to keep it running is to give it the gas. Which then for some reason thick smoke blows out the tail pipe. Some mornings it starts fine. No smoke and no noise. But sometimes after the car has been warmed up I start it and it will make the noise, but no smoke. and sometimes it don't make the noise at all. Any suggestions????
Old Feb 7, 2002 | 07:34 PM
ejj's Avatar
ejj
Re: PROBLEMS starting
What year car and how many miles?
95's are known to have a common starter problem.
All years suffer from problems with the ECTS (Engine cooltant temperature sensor) that would cause hard starting and possiable trouble idling when cold.
Old Feb 7, 2002 | 07:35 PM
Re: Re: PROBLEMS starting
97 se
Old Feb 7, 2002 | 07:38 PM
ejj's Avatar
ejj
How long does the noise last? You sure its from the starter? Check out www.motorvate.ca and the starter fix. I'd cure the noise and see if it helps with the idling and starting.
Old Feb 7, 2002 | 07:40 PM
Re: Re: Re: PROBLEMS starting
97 se
if my mind serves me right i had this problem with my starter... but when i turned on the car...the starter would still remain on ..as if i held the key down ... it was covered under my warranty and was fixed for free !!!!!!!!!!!!!!!!
so find out from nissan...if its some kind of recall..or if its covered
Old Feb 7, 2002 | 07:55 PM
the noise last only a second. I'll do that, I'll fix the noise then worry about the starting prob. if it is still there.
Old Feb 7, 2002 | 07:58 PM
ejj's Avatar
ejj
The problems seem to similar not to be connected. Fixing one may fix the other, but if it doesn't it will narrow things down considerbally.
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
cruce91
Sep 20, 2015 10:23 AM
trungg86
Sep 4, 2015 04:58 AM
dcardello
Sep 3, 2015 11:44 PM
