NEED HELP...its not a Maxima, but a J30t
Old Feb 8, 2002 | 03:53 PM
ExcelonGT
Hi,
I've owned a 93 Infiniti J30t for about a week now. Its an awesome car. However, I have this small problem. Today the dashlights started to act up. The radio and climate control lights work ok with the headlights off. As soon as i switch on the parking lamps or headlights...the radio and climate control lights go out...and the speedo, tach, and window control switches do not light up. I checked all the fuses but they checked out ok. Any body know what it can be? tahnks guys
-T.Ghosh
Old Feb 8, 2002 | 04:52 PM
Kevlo911's Avatar
Kevlo for President
check the dimmer controls it is prob all the way down
Old Feb 8, 2002 | 05:20 PM
pocketrocket's Avatar
Re: NEED HELP...its not a Maxima, but a J30t
Originally posted by ExcelonGT
Hi,
-T.Ghosh
This probably won't help, but I had the same problem when I installed my in dash changer. As soon as I turned on the lights, ALL illumination on the changer went out. Turns out, I didn'y hook up one of the illumination wire controls.
However, your problem seems to affect EVERYTHING, from the gauges to the center console headunit and climate control.
I guess I'd check the dimmer switch, don't know what else it could be. Could be a faulty dimmer switch maybe?
Old Feb 8, 2002 | 07:02 PM
iansw's Avatar
Yep...gotta be the dimmer switch. Turn it all the way to the right.
Old Feb 8, 2002 | 08:11 PM
95emeraldgxe's Avatar
the J 30 is the upgraded version of the altima right??? - but anyways....... could it be that the bulbs need to be changed?
Old Feb 9, 2002 | 06:27 AM
Kevlo911's Avatar
Kevlo for President
nope their are and only were 2 infins that were nissans max/i30 & pathy/qx4
Old Feb 9, 2002 | 06:46 AM
mzmtg's Avatar
Minister of Silly Walks
LAME POST!!!
No the J30 is not a fancy Altima.
Unless the figured out how to convert the Altima to rear wheel drive and put a VG30DE in the front...
halfpol
Oct 17, 2022 12:16 PM
Goffery2uned
Aug 21, 2015 09:50 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
