Spark plugs
Old Feb 8, 2002 | 03:54 PM
blakkrob's Avatar
Spark plugs
I changed my spark plugs last week and I noticed they had oil around the threads on the spark plugs. Is this normal? I also noticed that when I took the old ones out that a few of them were loose. I'm just hoping that I don't have bad seals or anything!
Old Feb 8, 2002 | 04:01 PM
SuDZ's Avatar
It is not normal or good. Sounds like bad head gaskets perhaps.
Check out this thread here
http://forums.maxima.org/showthread....il+spark+plugs
SuDZ
Old Feb 8, 2002 | 04:07 PM
blakkrob's Avatar
Head gasket?????????
Well I think if it was the head Gasket I would have water in my oil right? I'm hoping that all that this is excess oil that was spilled some how. If not how hard is it to change these gaskets?
Old Feb 8, 2002 | 04:58 PM
SuDZ's Avatar
I have never changed them myself but you might wanna take a look in a Chiltons or Haynes manual. If you dont have one get one for this, it will probably come in handy.
SuDZ
Old Feb 8, 2002 | 05:12 PM
pocketrocket's Avatar
Re: Spark plugs
Hey blackrob,
The plugs were still loose AFTER you tightened them in? I'm assuming you are refering to the new plugs being loose?
Is the car running smoothly? I was thinking you might have gotten the wrong plugs, but if it runs fine, it's not leaking through the plug threads.
And the oil on the plugs, were they on the new plugs or the old ones? You sure it's not anti-seize? Just trying to help.
Old Feb 8, 2002 | 05:38 PM
blakkrob's Avatar
Plugs
No the old plugs that I took out were loose when I went to remove them. I torqued the new in pretty good not too much though.
Old Feb 8, 2002 | 05:44 PM
Re: Plugs
Does it run good now then?
If it does, be HAPPY you changed your plugs
Old Feb 8, 2002 | 05:45 PM
garbear's Avatar
Re: Plugs
I have oil on my plugs too... It's coming from the head-cover-gasket. (I really don't think that's a real name though) but anyway...I've been thinking about replacing it but haven't gotten a chance. Check the plug hole....is there oil on the walls of that hole?
Old Feb 8, 2002 | 05:47 PM
blakkrob's Avatar
Plugs
Yeh it still runs fine.
Old Feb 8, 2002 | 06:52 PM
SuDZ's Avatar
Re: Re: Plugs
http://forums.maxima.org/showthread...oil+spark+plugs
SuDZ
magiconthetire
Oct 26, 2015 09:03 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
