Engine buildup
Old Feb 10, 2002 | 03:46 PM
SonicDust187's Avatar
Engine buildup
Guys how much would it cost to build a Maxima engine and how much power to you think it will make? Also whats the compression ratio on the Maxima engine?
Old Feb 10, 2002 | 04:13 PM
Bags's Avatar
VG Ridah's Biatch Hoe
Ok I see your new to this. Try searching, put compression ratio into the search and see what you get.
Building? What do you mean? New pistons? Block? TB?
Again try searching.. it will yeild some of the answers you need.
Old Feb 10, 2002 | 04:32 PM
SuDZ's Avatar
Without knowing some of your basic ideas it is hard to help you. Also what year is your max. Depending on what you have some ECU work can work wonders too.
SuDZ
Old Feb 10, 2002 | 04:46 PM
I don't have it yet I am going to a car auction on Tuesday to buy my car.
Old Feb 10, 2002 | 05:04 PM
JDM4LIFE's Avatar
well, the compression ratio is 10:1
if you actually are serious about rebuilding a maxima engine, you could always look into getting a vq35 also, what kind of build you do also depends on if you are going to run boost, or just go n/a...
Old Feb 10, 2002 | 09:09 PM
I will want it to be NA. But can a 3.5L engine fit into lets say a 97 max engine bay?
Old Feb 10, 2002 | 09:12 PM
NmexMAX's Avatar
dot dot dot ...
If you're going to tap into the heart of the vq30, just put the 35 in there, no tapping into, but fitment problems may be quite a concern. GOOD LUCK!! I've always wanted to see this be done, hehe, it would be kewl.
Old Feb 10, 2002 | 09:21 PM
Putting a 3.5L engine is not what im looking for but I do want to build the 3.0 engine. Do you guys know anyone who does this in the NYC area?
Old Feb 10, 2002 | 09:59 PM
SuDZ's Avatar
Nobody (at least on the forum) has attempted it yet. So give it a shot and ask around I'm sure you will find someone.
SuDZ
Old Feb 10, 2002 | 10:39 PM
1MAX2NV's Avatar
Anything is possible with $$$$$
Show me the money!!! That's what your local speed shop is going to say. Speed cost money, how much do you want to spend?
Old Feb 11, 2002 | 06:48 AM
Lets say I would wont to keep the 3.0L engine and bring its power up to about 250hp without rasing the compression ratio. I want to keep it at 10:1. If I could only find a shop thats in NYC or in Middle or Upper NJ that can do this. How much you think this is going to cost me?
James92SE
142
Jan 2, 2024 09:23 AM
Turbonut
46
Oct 21, 2015 08:28 PM
homewrecker
Sep 24, 2015 07:01 PM
msellas
Sep 23, 2015 09:16 PM
Socalstillen
Sep 20, 2015 11:46 PM
