Walbro pump makes idle high???
Old Feb 11, 2002 | 11:25 PM
nigelcmf's Avatar
hi there
i just installed a Walbro fuel pump last week. I have noticed that my idle speed is now at about 900 rpm up from about 600 before the install. I was wondering if this was a common phenomenon?
I will readjust my idle soon. Please let me know if these instructions are correct for setting idle:
1. Disconnect TPS connector
2. Adjust Idle screw to desired rpm
3. turn off engine
4. Reconnect TPS connector
5. Reset ECU???
Not sure if I need to do step 5, but I guess it wouldn't hurt.
Old Feb 12, 2002 | 12:20 PM
nigelcmf's Avatar
bump
Old Feb 12, 2002 | 12:58 PM
njmaxseltd's Avatar
Don't know if the raise in idle speed is common when you upgrade your fuel pump. It could be. On the other hand, your steps to adjust the idle speed are correct. Make sure your engine is all warmed up before you adjust it.
lowpost99
Oct 26, 2025 06:53 PM
Maxima.KsA
May 15, 2020 04:14 PM
BkGreen97
Apr 2, 2016 05:47 AM
sdotcarter
Sep 2, 2015 09:53 PM
Justin Kroll
Sep 2, 2015 11:06 AM
