knock sensor replaced -- cant believe my foot
Old Feb 12, 2002 | 11:14 AM
bosco500's Avatar
all i can say is HOLY ****!!! i knew my max wasnt pushing as much hp as it should have been (ever since i've had my sc) and i couldnt figure out what it was. anyway, ever since i've had it, when i run diag on my ecu, it give me a k.s. code. so i've finally decided to replace it. after i finished last night, i went for a ride. i was cruising at about 10mph in 1st gear, and stomped the pedal to the floor. i spun all the way through 1st gear, then spun half way through 2nd!!! i dont understand how the k.s. being bad could rob that much power from me, but i guess thats why i'm not a nissan tech gotta get back to the track!!!
Old Feb 12, 2002 | 11:33 AM
nismo2020's Avatar
Needs non-Maxima Friends
explian
how you changed it out. i think i have the same problem, cause my car is really down on power.
Old Feb 12, 2002 | 11:37 AM
SuDZ's Avatar
How much is a knock sensor anyway? Do you just get it from the dealer?
SuDZ
Old Feb 12, 2002 | 11:38 AM
bosco500's Avatar
Re: explian
its fairly easy if you have small hands. the ks is right under the manifold, you have to have a flash light to see it. get a 12mm socket and wiggle your hand in there and take off the bolt. the ks will come right out. unhook it from the harness, hook the new one up, and bolt it back in. it took me about 15 minutes and only 1 scratch
Old Feb 12, 2002 | 11:39 AM
bosco500's Avatar
SuDZ
i think their about 200 bucks from nissan, but i got mine for 75 from someone on the board
Old Feb 12, 2002 | 11:40 AM
SuDZ's Avatar
Re: Re: explian
Other than the small hands part it seems pretty easy. Does the ECU through a check engine light if your in need of one or do you just have to check the ECU to get the code?
SuDZ
Old Feb 12, 2002 | 11:45 AM
JAIMECBR900's Avatar
Re: Re: Re: explian
SuDZ
The ecu will give you a CEL and when you pull the code it will tell you. The KS is actually pretty delicate diagnostic part. I have read in the forums that, and it's also a part that some people say needs replacing after a while. It can get tripped by simple things like bad gas (causing pinging) and even CAI installs by the fact that sometimes trips the O2 sensors and the KS sensor together.
Old Feb 12, 2002 | 11:53 AM
bosco500's Avatar
most of the time the ks wont trigger the CEL. mine never came on, but when i ran diag on the ecu, it would through the code out.
Old Feb 12, 2002 | 11:57 AM
Right, what I was trying to say was that sometimes when the O2 sensor is tripped it will also give you the code for the KS.
Old Feb 12, 2002 | 12:04 PM
NmexMAX's Avatar
dot dot dot ...
I think it's time to replace mine, its the 3rd week in a row that it;s thrown the k.s code at me, where exaclty is it under the intake manifold?
Old Feb 12, 2002 | 12:09 PM
It's right under the intake manifold. It looks like a little metal top. If you look from the battery side of the car, straight across the fender well under the manifold and little to left, that's it. (How'd yall like those directions). BTW I too have a pebble beige 95.
bosco500's Avatar
its pretty much the only thing up under there that is bolted down and has a harness running to it. get a flash light and shine it under the right side of the i.m., and it is dead center of the manifold.
Old Feb 12, 2002 | 04:40 PM
boogiemax95's Avatar
here you go
This should help. It real easy to take out if your hands are small. But if they are not like mine. You need and extention to get in to there.
Posted by bill99gxe on 08-02-2001 04:21 PM
DTC 0304
Diagnostic Trouble Code 0304 points to a problem with the Knock Sensor. The KS
is attached to the cylinder block. It senses engine knocking using a
piezoelectric element. A knocking vibration from the cylinder block is senses as
vibrational pressure. This pressure is converted into a voltage signal and sent
to the Engine Control Module (The computer).
This malfunction is detected when an excessively high or low voltage from the KS
is entered to the ECM. Possible causes include...
- the harness or connector (The KS circuit is open or shorted).
- the KS
The KS may be checked with an ohmmeter.
1) Raise the hood. View the engine from the driver's fender. Look into
the deep valley between the cylinder banks and below the intake manifold.
Identify the KS as a black item fastened to the block by a single vertical
bolt. A wire harness wrapped in black leads toward you, out of the valley.
That is the KS sub-harness.
2) Follow the KS sub-harness to it's nearest connector. This is connector F121.
It is located near the upper right-hand corner of the valve cover of the forward
cylinder bank, as viewed from the front of the car.
3) Disconnect F121. You have to do a "press the latch and wiggle and
pull" to disconnect it. F121 has only two pins; if you see more than two
pins, you have the wrong connector. Use a digital ohmmeter capable of
measuring more than 10 Megohms. You want to measure the pins of F121, not
the sockets of the matching connector. Measure the resistance between a
good ground (such as the battery negative terminal) and pin #2 of connector
F121. On my car this is the highest of the two pins, the one closest to
the front of the car. The factory spec is 500 - 620 Kohms.
The manual says you have to remove the intake manifold to replace the KS.
However, I think that a person with good dexterity and a 10mm ratcheting box
wrench could replace the KS without disturbing the manifold.
Old Feb 12, 2002 | 06:00 PM
sp6040's Avatar
well i guess its about time i stop ignoring that k.s. code i also got a vehicle sensor code which i think is the reason my speedometer stickes from time to time.anyone one from here replace v.s.s on their own?
Old Feb 12, 2002 | 07:43 PM
GreenMaxVE's Avatar
I just replaced my KS also and noticed a huge power increase . I have a 3rd gen SE so I had to take the entire intake manifold off to get to the sensor, but it was well worth it. It turns out that the connector at the sensor was all corroded and not making contact anymore. The old sensor still works after cleaning it up, but I put the new one in anyway. I ordered the KS through Courtesy for $135.
Old Feb 12, 2002 | 08:01 PM
matty's Avatar
This may be a stupid question but you do the test with the engine running or not ??
Old Feb 12, 2002 | 10:44 PM
SuDZ's Avatar
Huh. I dont get a check engine light or anything but maybe one day I will check the ECU to see if I get a code from anything. It could be one of those things that if needed I guess I will go for. Good to keep in mind anyhow.
SuDZ
Old Feb 13, 2002 | 11:25 AM
SuDZ's Avatar
Okay one more question. Is there a way to visually tel if your in need of a new sensor. Like if I took it out to inspect it can you see and defects or what not that would lead you to believe you need a new one?
SuDZ
Old Feb 13, 2002 | 11:34 AM
bosco500's Avatar
SuDZ
to tell you the truth, when i pulled my old one out, i couldnt tell the 2 apart.
Old Feb 13, 2002 | 12:18 PM
kchida's Avatar
i had the 0304 knock sensor code for a while and decided to replace my KS last week. I definitely noticed better performance(especially in the higher RMPs) and kinda solved my ****ty gas mileage problem. I ordered through a friend of mine and got it for $140 but i found a better deal at this site for $128:
http://www.nissanparts.cc/partsearch...ber=2206030p00
My old KS kinda threw me off because it gave a reading of 5MOhms then after awhile it would be the normal ~550kOhms. I think the piezo element inside wasn't behaving consistently, throwing weird voltages. So if your KS tests OK but you still have the problem, you might want to check it a couple times. I did the test on my brand new KS and it gave a reading of 550kOhms consistently every single time i tested it. Also, i was able to change the KS without removing the intake manifold too. I just used a 12mm socket w/ and long extension and a universal joint. then i stuck my "little hands" up in there and unscrewed the rest. One last suggestion, WEAR A THICK RUBBER GLOVE OR SOMETHING cause the f$#cking sharp edges in there shredded my hands up!!
Old Feb 13, 2002 | 12:30 PM
SuDZ's Avatar
Cool thanks guys. Maybe I will test the ECU and check the KS one day. I dont think I have any problems but like knowing that if I did I would be able to find out before anything worse seemed to happen.
SuDZ
Old Feb 13, 2002 | 12:38 PM
nismo2020's Avatar
very good info
this should be a sticky.
nismo2020's Avatar
very good info
Old Feb 13, 2002 | 12:50 PM
Cumalot's Avatar
Is there any sign that can tell you the knock sensor need to be replaced? Like the way your car is running or any abnormal sound for example? My car is running pretty good, the only questionable item is the tranny.
Old Feb 13, 2002 | 01:06 PM
bosco500's Avatar
I started to notice a lag in power, and also the 1st time I ran at the track I ran a 15.4 w/ my sc. I ran a 15.6 at maxus and I KNEW something was wrong, just couldnt figure out what. I also noticed that at low rpm's in 3rd and 4th gear (while accellerating) the car would lag.. almost like it was shooting fuel in spirts, and not a smooth flow. hope this helps.
Old Feb 13, 2002 | 01:41 PM
SuDZ's Avatar
How long do they last? Is it somethign that needs replacing eventually or is it just some last some dont?
SuDZ
Old Feb 13, 2002 | 01:54 PM
Cumalot's Avatar
Yes, Thanks.
Old Feb 13, 2002 | 02:45 PM
GTRBlkMax97's Avatar
that's exactly what I was looking for, I have the same problem, i guess I need to spend some more money
Old Feb 13, 2002 | 02:59 PM
SuDZ's Avatar
Huh, If I check mine out and find out I have been losing power in it then maybe my et times will lower. Or maybe I will find out it is fine and it is just me
SuDZ
Old Feb 13, 2002 | 03:44 PM
NmexMAX's Avatar
dot dot dot ...
SuDZ
Some ppl on here have noticed nearly a second of their 1/4 mile times
Old Feb 13, 2002 | 04:27 PM
KWheelzSB's Avatar
Seriously? That's f'n HUUUUGE. -Anyone here vouch for that? Maybe I'll be pulling codes this weekend. . .(That's all I need - spend more $ I don't have!!!)
Old Feb 14, 2002 | 03:51 AM
nismo2020's Avatar
i feel ya samething here.
Old Feb 14, 2002 | 04:20 AM
rguida's Avatar
heres the real question.....can their be something wrong with your knock sensor and your ecu not pick it up? with an intake and a cat-back exhaust i manage only a 15.6 in a 5 speed......
Old Feb 14, 2002 | 06:56 AM
NmexMAX's Avatar
dot dot dot ...
Herre's the thread
https://maxima.org/forums/showthread...5&pagenumber=1
Old Feb 14, 2002 | 08:50 AM
ivolley's Avatar
Did you get rid of the resonator
Old Feb 14, 2002 | 08:54 AM
NmexMAX's Avatar
dot dot dot ...
Re: Did you get rid of the resonator
Originally posted by ivolley
Not yet, still need to figure out the vacuum lines. I may just buy a PR or WSP upper tube.
U still like yours?(or lack of res. should I say)
Old Feb 14, 2002 | 09:26 AM
Sonic's Avatar
That was me.
To clear things up, no, you won't get a CEL, but it will show up as the 0304 on the diagnostic. You can test the part, but a bad sensor may still test within spec. Its a solid piece of plastic with a bit of metal running through it, so you can't visibly inspect it and tell if it is bad. Yes, you can replace it yourself. It is located directly underneath the center of the upper intake manifold, is held on with ONE 12 mm bolt and if you have small hands, can be taken of without moving the intake manifold. The part is about 140 from the dealer. As for the drop of 1/4 mile times, it took 1.1 seconds off of mine when I replaced it, so it HAD to be retarding timing. THIS DOES NOT MEAN THAT CHANGING IT WILL MAKE A CAR RUNNING 14s INTO A CAR RUNNING 13s. If the KS in your car is fine, it will not lower your time.
Old Feb 15, 2002 | 05:02 PM
sp6040's Avatar
i must have to replace mine i have definatly noticed a loss in power.
Old Feb 15, 2002 | 06:54 PM
190hpKiLLA's Avatar
Granny Driven
Help here!!
Is it something I have to replace eventually or if its good then dont bother with it??? Thank you
Old Feb 15, 2002 | 08:01 PM
bosco500's Avatar
Re: Help here!!
i wouldnt mess with it unless its bad.
