Can someone post instructions for how to replace driver's side mirror? (1998 GXE)
Old Feb 16, 2002 | 02:44 PM
Alexander's Avatar
My girlfriend managed to demolish my driver's side mirror... in anticipation of buying a second hand replacement, can someone please post instructions from some uber-manual about how to replace one of these things? Is it feasible to do it one's self?
Thanks!
- Andrew
PS - here's a photo for the damage junkies.
Old Feb 16, 2002 | 06:42 PM
Ravq's Avatar
Step 1 - Remove interior door panel. (http://carstereohelp.com/stereoremovalNisMaxFSpk01.htm)
Step 2 - Carefully pry up the plastic cover.
Step 3 - Remove the sail trim panel
Step 4 - Disconnect electrical harness (if applicable)
Step 5 - Remove the mirror attaching screws (there should be 3 of them), then carefully pull the mirror from the door
The installation is self-explanatory. Good luck.
Old Feb 17, 2002 | 07:33 AM
Alexander's Avatar
Thanks Ravq!
Andrew
Old Feb 17, 2002 | 07:43 AM
NickStam's Avatar
are you sure you can't remove the mirrors just by undoing the screws behind that triangle shaped piece on the inside?
Old Feb 17, 2002 | 07:51 AM
Ravq's Avatar
Good point Nick. Now that I look at it I believe you can. The Chilton must be referring to the 3rd Gen procedure. Andrew I would try removing the triangle shaped cover on the interior of the door first. If it is not attached or held down by the door panel you'll have a lot less work to do. Sorry if I mislead you.
Old Feb 17, 2002 | 08:24 AM
NickStam's Avatar
Just check out the easy possibility first
Old Feb 17, 2002 | 12:19 PM
Alexander's Avatar
Thanks guys, that would indeed be a lot easier.
On the plus side, it turns out that only the supporting plastic is damaged, not the coloured portion of the mirror assembly. So when I get my mis-coloured replacement I can just swap out the pieces and not bother having to repaint.
I'll let you know how it turns out...
Andrew
kingw323
20
Oct 21, 2015 08:36 AM
rtirbany
Sep 8, 2015 11:46 AM
kirkhilles
Aug 8, 2015 10:53 AM
erniel
Aug 8, 2015 09:32 AM
dauntlessmax
Aug 5, 2015 10:29 AM
