Fuel filter hose
Old Feb 18, 2002 | 08:16 AM
sarmast's Avatar
Fuel filter hose
Anyone know where I can buy the hose that goes from the fuel filter to the engine? I know nissan sells it in that set length, but I want it longer because I AM SICK AND TIRED of leaving knuckle skin all over my firewall as as wrestle with getting the damn thing off. This weekend I absolutely could not pull the top hose off so I had to cut it, I won't be able to do that next time, not enough length left.
BTW, it hurts when you get gas in an open wound.
Oh yeah, and I have ABS, so that makes it harder (i've heard, I've never seen a max without abs)
Old Feb 18, 2002 | 09:06 AM
ejj's Avatar
ejj
Re: Fuel filter hose
Any parts store should have it. You need 5/16" FI hose. Make sure its the high pressure hose (100psi), 'cause normal fuel hose (up to about 20psi) just won't cut it!
A foot of the stuff costs about $3-$5 depending on what store you go to.
Don't get 1/4", that's what I accidently did. It doesn't cause any problems, but may incorrectly raise fuel pressure.
Old Feb 18, 2002 | 10:25 AM
HSVMaxima's Avatar
This may help
This weekend I used a hair dryer to warm up the hose and it came right off.
Old Feb 18, 2002 | 10:26 AM
HSVMaxima's Avatar
OH yeah
Removing part of the intake system, ie to clean the throttle body helps too.
Old Feb 18, 2002 | 10:34 AM
Justin95SE's Avatar
i dont have ABS, 95SE
Old Feb 18, 2002 | 11:55 AM
sarmast's Avatar
Re: Re: Fuel filter hose
I know they came without ABS, I've just never seen the engine of one.
Old Feb 18, 2002 | 01:06 PM
Maximus44's Avatar
me toooo
holy sht bro i was in your exact same boat that u were in. i coulnt get the damn hose off the filter so i cut a little slot in it. so i ended up goin to autozone. the damn hose only costs 99 cents a foot. o yeah by the way *** gas on a cut i got gas all over my arm and that **** drys ur skin and makes it burn like a mother.
marc
Old Feb 18, 2002 | 01:21 PM
ejj's Avatar
ejj
Re: me toooo
marc
I think you got the wrong hose. It doesn't sound like Fuel Injection hose, that just fuel hose. There's a BIG difference. Regular fuel hose can't handle the pressure of a FI system.
Look at the hose...does it say something along the lines of Fuel Injection, High Pressure, or 100PSI? If not, you should get the right hose ASAP. FI hose costs a lot more than 99 cents/foot.
Old Feb 18, 2002 | 02:17 PM
sarmast's Avatar
Re: Re: me toooo
I saw the stuff he was talking about at autozone, it is not the high pressure stuff and he should replace but don't forget the factor of safety that stuff has, I'm sure he'll be fine until something unusual happens, but then you never know when something unusual is going to happen.
Old Feb 19, 2002 | 12:01 AM
spiff56747's Avatar
for me it was much eaiser to pull the top hose out of the engine side than from the top of the fuel filter... you just pull really hard toward the firewall.. then after that it came off easily from the fuel filter.. the bottom hose was still a b!tch though
Old Feb 19, 2002 | 06:39 AM
dwapenyi's Avatar
It took me 2 hours to change my feul filter last time. let's just say I'm not good when working in small tight places
Anyways, Steve Cutchen's MaxFAQs had a really good suggestion, remove the feul filter AND the hoses together. Replace the filter while it's outside, then put it all back in.
Also, thx to Bill the moderator's suggestion, I'm using the 300ZX filter, so I can wait to change at at 60K miles instead of 30K miles for the stock one.
http://web2.airmail.net/scutchen/max...lter/index.htm
DW
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Justin Kroll
Oct 1, 2015 07:03 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
