PSI for 235/40/18 tires
I have some Sumimotto 235/40/18 Z rated tires, and am not sure what to inflate to. They say 51 PSI max on the side, my spare (a Khumo Escta 712 Z rated, same size) says 44 PSI max.
Any ideas (normal and track)?
Re: PSI for 235/40/18 tires
As for track, I am clueless.
Re: Re: PSI for 235/40/18 tires
Originally posted by bill99gxe
Michelin's website has a convoluted method for obtaining a tire recommendation for Maximas with "Plus 1" 235/40 18s. They recommend 33 PSI front and back in that particular size.
Just for some real life data for you I run about 34 in mine
You don't want to overinflate them, but the more pressure you run the more it evens out your ride. I usually err slightly on the high side in case I lose some pressure over time.
-hype
![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
-hype
