fuses
Old Feb 19, 2002 | 08:28 AM
fstmax1's Avatar
fuses
is there a fuse for the driverside door light...mine doesnt work and its not the bulb...where is the fuse located thanks
Old Feb 19, 2002 | 09:12 AM
Chunger's Avatar
My other car is a Hybrid
Does the dome light go on? If not... it's probably the door switch
Old Feb 19, 2002 | 09:21 AM
HondaKiller718's Avatar
Re: fuses
If you have a voltmeter use it to check for voltage, if you find voltage then something is wrong with the bulb or the bulb's connection. If you don't find voltage. Check under steering wheel (on the left hand side) for your fuse box cover. Pull it out to reveal you fuse box and a diagram of what fuses and where they should be is attached to the fuse box cover. Take a look and replace what you need to.
leatherneck
Sep 30, 2015 09:16 PM
Junebug1701
Sep 25, 2015 01:54 PM
conansriver
Sep 16, 2015 12:17 PM
jwright36
Sep 8, 2015 11:45 AM
