EVAP control system pressure sensor???
Old Feb 20, 2002 | 03:54 PM
elcid's Avatar
I got error code 0704--'EVAP control system pressure sensor" What the hell is that? Is it expensive? Is it bad for me to drive my car? and also my rear O2 sensor keeps going off, it's only 2 months old. Why does it keep going off every once in a while? thanks.
Old Feb 20, 2002 | 03:57 PM
spiff56747's Avatar
Re: EVAP control system pressure sensor???
I had code 0704 and 0215, the 0215 being the EVAP CV control valve.. Also, my fuel filter was clogged so my car didnt get enough fuel at startup( I dunno if this was related)..
So, I replaced the fuel filter.. Then I found the CV control valve, greased it with WD40, and put it back on.. Now the car starts fine and the CEL is gone..
Old Feb 20, 2002 | 04:00 PM
elcid's Avatar
THANKS! I'll try greasing it up. I know my fuel filter is fine cause I just put a new BOSCH one in about a month ago. Time to go grease that **** up.
Old Feb 20, 2002 | 06:58 PM
XXXL Cracker's Avatar
0704
You also may want to make sure that you have your gas cap on tight. The actual EVAP canister is located slightly behind your right rear tire and can be removed simply. You could have several things happening. Do a search for 0704 and you will find the information you need.
Good luck!
DL
vybz05
Dec 10, 2015 07:38 PM
Slamrod
Sep 3, 2015 07:38 PM
lux97Max
19
Aug 27, 2015 07:48 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
doobadoo
Aug 15, 2015 06:43 PM
