suspention
Old Feb 23, 2002 | 03:44 PM
cwinn
suspention
I have entirely too much stereo equipment in my trunk and it is causing the rear end to sag 1.5 to 2 inches. anybody know how to raise the rear end back to stock height short of tossing the stereo? The suspention is still OE.
Old Feb 23, 2002 | 05:18 PM
Xtreme5053's Avatar
Re: suspention
Three words: Jack on Wheels.....
I don't thinks there's any good way other than getting stiffer springs or shocks (they need more weight to be depressed the same distance, i know this is how spring rate is measured, i don't know how effective stiffer shocks would be though). If this helps, great, if it doesn't, sorry, it's the best i could think of. Good luck!
P.S. Big car = Room to BOOM! Gotta love the bass...lol.
Old Feb 23, 2002 | 05:32 PM
pawn's Avatar
airsuspension!
Old Feb 23, 2002 | 05:51 PM
WizzaMax's Avatar
Easy fix and inexpensive is the polyurethane spring inserts that you can get from Pep Boys or AutuZone that slip in between the coils in front and rear of each spring...when unsprung of course...offers either 1/2 inch or 1 inch help according to dimensions but of course this will depend on where you place them and how much potential space you have now.
BTW approx how much weight are you carrying?
Old Feb 23, 2002 | 06:20 PM
cwinn
BTW approx how much weight are you carrying? [/B][/QUOTE]
Probably 250-300 lbs betweene the subs, enclosure, amps, amprack, and all the other essentials.
I'll give the spacers a shot though.
Old Feb 23, 2002 | 06:25 PM
party_boy's Avatar
i used the rubber spacers
that i bought from kragen for 5 bucks. It raised my rear end about 1.5inches
Old Feb 23, 2002 | 06:32 PM
araffio's Avatar
You could also try lowering the front 2 inches with some Sprint springs. I think they have a lowering height of about that. This will even it out with the back and give you a better look.
Just a thought.
Old Feb 23, 2002 | 06:49 PM
Mishmosh's Avatar
KONI adjustable rears have a raised setting that bumps the back end about an inch and a quarter higher without affecting the springs... designed specifically for people with back end loading. Basically, it moves the lower spring bracket up on the shock. I think spring inserts would affect the ride, potentially for the worse.
2blue
Jan 10, 2008 07:26 PM
nitink
Apr 23, 2007 12:06 PM
maxspeed96
Jun 4, 2005 01:10 AM
The Russian
Mar 28, 2005 08:57 PM
