4th gen. Audio Question....
Old Feb 26, 2002 | 04:24 PM
SilverBullet98's Avatar
I am in the process of upgrading my stereo...Head Unit, speakers, amp, subs, the whole deal... I have a 98 SE with the BOSE, does this car have seperate amps for the BOSE system like my 3rd gen. did, and will it have a whining noise like my 3rd gen.....2- What size are the speakers ( front and rear ) And can you guys recomend any speakers...Anything esle I need to know about the stereo that I need to know ??? Thanks for the help...I posted this in the Audio section, but I got no answers...
Old Feb 26, 2002 | 05:01 PM
gtr_rider's Avatar
192.168.1.1
Each speaker has its own amp, thats correct. Each amp is really expensive so be careful with it.
Specify what you mean by whining noise...
I believe its 5 1/4 in front, 6 1/2 in the rear
GMT_MAX's Avatar
I don't have the Bose system, so I don't know about the separate amp question, but the speaker sizes should be the same. The Max has four 6.75" (round) speakers, so without too much (or any) modification, you should be able to get some standard 6.5" or 6.75" speakers in there. Crutchfield is a good audio reference site (even if you don't end up buying from them) - they'll let you search for speakers and such that fit your car. Are you going for a huge system or do you just want something that sounds good? If you're looking for something outlandish, you'll have to do some tearing up of stuff to get all the equipment in there.
I replaced my head unit w/ a Kenwood a few months ago and only recently have noticed a whine, which is kind of annoying, so I may have to spend some time trying to figure out where that's coming from. Maybe I didn't notice it before because I was always listening to loud music, or maybe it's only just started, I'm not sure. It's really only noticeable when you're listening to soft music, though, so just turn it up.
Old Feb 26, 2002 | 05:31 PM
eelcram's Avatar
Re: 4th gen. Audio Question....
it's 6.5" all around. front and rear
Old Feb 26, 2002 | 05:32 PM
rguida's Avatar
I used to have horrible whining noise.....and after months of dealing with it, have figured out...that 95% of the time, it is a bad ground....look at that as the problem first....
Old Feb 26, 2002 | 05:56 PM
meccanoble's Avatar
Sports Button FTW
lol, i remember when i had my speakers, i blew them sh*ts, i mean i litterally put a big a$$ hole in them and they were making this horrible sound...only one of my front speakers survived but changed it anyway cause it wasn't long before it was going to die on me too....and mine looked exactly like the ones posted above....they make good sound better than my new ones due to my weak head unit but they all paper made, look so cheap compared to my rubber MTX 6X9's in the back and (forget size) in front.....
Old Feb 26, 2002 | 06:04 PM
Sprint's Avatar
they are 6 1/2S all around.. which means they are a little bigger than 6 1/2's but 6 1/2's fit anyway..
your noise was probably due to your altenator.. or incorrect amp wiring..
when you wire your amp.. run it along the side of the car.. and run your RCA cables down the middle
these might help you out also..
Old Feb 27, 2002 | 09:14 AM
Thanks for all the help guys....What about hooking up an amp and subs to the stock BOSE headunit ?? Advantages / Disadvantages ??
Old Feb 27, 2002 | 09:28 AM
Big_Ham's Avatar
MaximaFreak
Disadvantage is that you will need a line level converter and you will not get as clean a signal as you would with a high voltage pre-out. This will "dirty" up the signal and you will have to crank higher for the same sound. You will possibly induce noise into your system and you will definitely not get the same sound as with a pre-out. Spend the extra money on a head unit, it will make for easier expansion later, and if you get a single DIN unt, you can get an extra pocket for below the radio for storage
Old Feb 27, 2002 | 09:38 AM
Yeah, I have the head unit, I am just worried about having the car taken apart...It's so tight and quiet...I dint want to mess with that...but, I'm gonna get 4 new speakers, the HU and amp subs all installed....But should I have the BOSE amps bypassed like I did in my 90 Max ??
Old Feb 27, 2002 | 09:57 AM
Big_Ham's Avatar
MaximaFreak
Absolutely.
Old Feb 27, 2002 | 11:11 AM
Toolrocks's Avatar
yeah, bypass them and remove them. They're dead weight. PLus depending on what kind of speakers you get you can mount the crossovers in the factory amp locations.
James92SE
142
Jan 2, 2024 09:23 AM
MAXSE5SPD
Sep 17, 2022 04:00 AM
Fbana41
Aug 29, 2016 12:18 PM
worldwiderecognized
Sep 24, 2015 06:56 PM
lrb6805
Sep 24, 2015 05:03 PM
