HELP !!!! Headlight problem this morning!
Old Feb 27, 2002 | 04:37 AM
nismo2020's Avatar
Needs non-Maxima Friends
okay i got in my car this morning and i turn the headlights on and nothing happens except the highbeam indicator is on in the dash. i look at the front of the car and no headlights just parking lights. i push the stalk to highbeam and only the right headlight comes on. i pull it back and the right headlight goes out but i still have a high beam indicator in the dash. when i turn the lights completely off then turn them back on the high beam indicator goes out. basically my headlights dont work i was just wondering is it possible that it is a electrical glitch. as soon the sun comes up i will check to see if the headlight bulbs are not blown.
Old Feb 27, 2002 | 05:26 AM
amixam98's Avatar
Sounds like your harness is toasted. The highbeam indicator shows up when your harness is gone. Sorry bro. Happened to me..
Old Feb 27, 2002 | 05:40 AM
nismo2020's Avatar
thanx, will it actually be fryed? you know can i physically see that its gone?
Old Feb 27, 2002 | 05:47 AM
amixam98's Avatar
Pull out the lightbulb and look at the harness. Compare the two. You should be able to tell. It should be clean if it's ok..
Old Feb 27, 2002 | 05:48 AM
theblue's Avatar
what kind of bulbs were you running?
Old Feb 27, 2002 | 06:02 AM
ejj's Avatar
ejj
I've had other Nissans that did this when the blubs burnt out, not just a fryed harness. You could just need new bulbs.
Old Feb 27, 2002 | 06:41 AM
amixam98's Avatar
Try switching bulbs from one side to another. It might work again if you put your factory bulbs back in.
Old Feb 27, 2002 | 06:54 AM
nismo2020's Avatar
hiper industries "hids" you know which ones im talking about? i dont see why they would fry my harness. is it cause the light output is higher?
Old Feb 27, 2002 | 07:01 AM
amixam98's Avatar
I'm running the same brand.. 55w or 80w?
DJLAX152
May 4, 2021 11:46 AM
Mar 12, 2020 12:06 AM
markevans999
Sep 10, 2015 04:29 PM
mpbclutch33
Sep 8, 2015 06:21 PM
nbstriker10
Sep 4, 2015 04:26 PM
