Headlight cleaning
Old Feb 27, 2002 | 10:45 AM
asianmotorsports2000's Avatar
Headlight cleaning
What can you use to clean the lenses of your headlights? I am talking about taking them apart and cleaning the inside of the lens and possible the reflective surface on the body of the headlight itself...
Old Feb 27, 2002 | 10:46 AM
njmaxseltd's Avatar
Windex and a very soft lint free towel.
Old Feb 27, 2002 | 10:59 AM
Toolrocks's Avatar
Cheston's site maximadriver.com has instructions on this in his how2 section. I think he uses lighter fluid though. I guess it evaporates better and has less chance of streaking than windex. Let us know how it goes. I was debating doing this. Good luck.
Old Feb 27, 2002 | 11:13 AM
Str8ridin's Avatar
WHOAAAA....NON-FLAMABLE...for the sake of your car buddy....
Old Feb 27, 2002 | 11:42 AM
jt151's Avatar
Glass cleaners will dry your lenses and leave them looking foggy. Try using armorall, son of a gun, or some oil-based cleaner. It will replenish the moisture and give it a better shine.
Old Feb 27, 2002 | 06:46 PM
Toolrocks's Avatar
Yeah, I think I was on crack earlier. I checked his site and it says alcohol, not lighter fluid. Either way, don't drink either of em. I would not use anything oil based - that will smear, streak, and probably cause problems when the bulb heats up the glass. Chestons info that I am referring to is in the how2 section under "Make AE headlights" good luck.
Old Feb 28, 2002 | 01:52 PM
maxxed's Avatar
If you have the 95 glass headlights, I believe the lense is glued to the reflector, you have to heat them up just to remove the lense.
Old Feb 28, 2002 | 04:15 PM
ny96max's Avatar
i use Mothers Plastic Polish and paste wax on the my headlight lenses all the time. Keeps them very shiny.
and yes i have upgraded to 99style headlights
Ant
Old Feb 28, 2002 | 09:38 PM
WizzaMax's Avatar
Use cotton ***** soaked in rubbing alcohol and drop them inside the bulb hole...move around carefully with eraser end of a pencil.
AaronL
Nov 15, 2020 11:52 AM
Vistance
Sep 17, 2015 05:17 AM
seesole
Sep 14, 2015 12:38 PM
mpbclutch33
Sep 8, 2015 06:21 PM
sdotcarter
Sep 2, 2015 09:53 PM
