OH YEAH! finally get to drive my car
well the agony is over.
I bought my 95 SE max over two weeks ago and due to some stupid reasons the paperwork was delayed and FINALLY
i get it today and i can't wait to drive it. ( got to get it registered first).
So i've been on this board for reading and drooling over the mods that have been done and i can't wait to get started.
First though i would like to make sure the car is running 100% b4 i start modding the motor.
The cars got 95K miles on it and i plan on giving it a full tuneup just so i can keep track of service records.
This is what i plan to change.
NGK R platinum plugs
change oil
new pcv valve
new gas filter
got a stillen cone filter (pop charger?) on order
is there anything else that i should do?
i also think the timing chain tensioners need to be changed cuz i hear this slight clanking noise from that area.
well i'll keep you posted on my mods.
i'm takin the car to the autogear show next weeks hope to see some of you guys there .
Thanx in advance
ANT
change oil
new pcv valve
new gas filter
Thanx in advance
ANT
See if the starter was ever replaced. Mine went at 60k miles so I imagine your okay but if not, keep an eye on it. Other than that you should be good to go! Enjoy the ride and I'll see you at the meet!
Jim
Jim
change oil
new pcv valve
new gas filter
Thanx in advance
ANT
change oil
new pcv valve
new gas filter
Thanx in advance
ANT
Also check your two engine coolant hoses and the smaller hoses as well. I replaced all of mine just to be safe after 4 1/2 years and 96,000 miles.
Originally posted by speedtrip
I did a tune-up on my max 2 months ago when it had 96,000 miles on it. I replaced all the fluids\filters and accesory drive belts. The biggest improvement for me was the brakes. I replaced the brake fluid and bleed the system and now the brakes are working great. Before I did that I would have to press the brake pedal to about the halfway point to get strong braking. After I replaced the brake fluid now I get strong braking about 1/4 way down. Don't forget to check the brake pads and the condition of the brake lines.
Originally posted by shane
I have a stupid question but how can you tell if the starter is going and what yr Maxima has the bad starter thanks
Hondarydr
Dec 30, 2024 06:15 PM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
yat70458
Aug 3, 2015 01:16 PM
Bad Luke.
