TIRE SKIPPING- WHAT IS CAUSEING IT???????
YO I GOTTA QUESTION. SAW IM AT A LIGHT AND TURNING RIGHT.( I HAVE A COLD AIR INTAKE) , SAY I HIT THA PETAL A LIL AND U START HEARIN THA INTAKE SUCKIN THA AIR FROM OUTSIDE. WELL ONCE I HIT THIS THE CAR BECOMES REALLY QUICK, AND THEN STEERING KIND OF WOBBLES AROUND. AND SOMETIMES THA TIRE SKIPPES AROUND ON THA ROAD ( I HAVE NOT LOWERED MY CAR) IZ THIS THE REASON WHY??
It's your tires not gripping the road. Even with super sticky performance tires, my Maxima spins the wheels when it is wet outside. It's exactly what you describe...you step on the gas, and then the steering gets all loose and vibraing.
Just don't step on the gas so hard and the tires will grip up.
same here
with the steering pull and tire hop when I merge into the highway very quickly. It has to do with the grip of the tires, but it also has to do with the type of road surfaces you are travelling on. I notice that I don't get that when I floor it on the white cement type roads--which are louder but I think it is better with road grip. With the black asphalt--whoaaa...better watch that when the road is wet or when there is ice--that type of surface is very quiet to travel on and will minimize road noise--but it is slippery.
If it's wheel hop, I read that that can be caused not only by what the above (and I am sure better qualified individuals thatn myself-for real) say but also suspension. On front wheel drive cars especially. The torque makes the weight shift to the rear of the car taking the weight off the driving wheel(s) and the car's tires can't grip so the torque applied to moving the car just spins the tire causing the weight to quickly transfer back to the fornt wheels and violah, tire hop, I think.
- Slow your starts, accelerate more slowly
- Install grippier tires (bigger, wider, stickier)
- Firm up your suspension (springs, struts, FSTB)
- Replace the OEM rubber engine mounts with stiffer mounts
The first suggestion doesn't cost anything, it doesn't lead to a harsh, bumpy ride, nor does it induce more noise and vibration in the cabin. It *will* prolong the life of your drive-train.
Originally posted by Gotrice4
This would probably be torque steer, its when one wheel spins and causes a pull to that side, if you have an auto it is exaggerated even worse on a max, tires are always a factor(air pressure, type, wear)
Mar 12, 2020 12:06 AM
Serotta33
Sep 17, 2015 12:14 PM
