Friend Is An Idiot
Old Mar 5, 2002 | 03:09 PM
lgsmaximaman
Friend Is An Idiot
OK I HAVE A QUESTION MY FRIEND AND I PUT IN A CAI OVER THE WEEKEND NOW MY FRIEND WAS PUTTING THE BATTERY BACK IN AND HE "ACCIDENTALLY" TOUCHED THE NEGATIVE TO THE POSITIVE SIDE. NOW I HAVE NO POWER WINDOWS HEATER OR CD PLAYER, THE 140 AMP BATTERY FUSE IS FRIED AND I THINK THERE IS A CIRCUIT BREAKER BEHIND THE FUSE BOX. BUT MY QUESTION IS HOW DO I GET THESE THINGS BACK TO WORKING AGAIN??
Old Mar 5, 2002 | 03:16 PM
SuDZ's Avatar
First you have to STOP TALKING IN CAPS.
No you can replace the fuses he blew. Check em all including the ones under the steering wheel area to make sure those are not dead also.
SuDZ
Old Mar 5, 2002 | 03:19 PM
lgsmaximaman
ok thanks sudz sorry bout caps i am at work and the program we use only works in caps...thanks i will give the fuses a try....if it doesnt work got any other suggestions? thanks
Old Mar 5, 2002 | 03:42 PM
SuDZ's Avatar
Well did the main block under the hood looked bad too? It will be in a little case, take a look at those. Was the car on when he hit the terminals on the battery?
SuDZ
Old Mar 5, 2002 | 03:48 PM
lgsmaximaman
no it was not on it hasnt been on in a while it is away for the winter. there is a 140 amp fuse in the case next to the battery that fuse blew all the ones under the steering wheel are fine. ??
Old Mar 6, 2002 | 09:43 AM
Black97GLEnj's Avatar
SuDZ
How could the car have been on if he was putting the battery back in? Anyway, my brother did this in his old jeep and he fried just about every fuse. Almost everything worked after he replaced the fuses, except for the power seats and mirrors. Good luck
Old Mar 6, 2002 | 10:06 AM
97MaxSE's Avatar
That program blows....
Old Mar 6, 2002 | 10:15 AM
iansw's Avatar
Let me guess...an old AS400 Inventory App?
I remember when I had to set up 2 AS400's to talk to each other over a 14.4k connection. They only respond to CAPS. And you'd type a letter, and 20 seconds later you would finally see it on the screen because the stupid AS400's would verify packets between the 14.4k connection before it put anything on your screen.
So your "T" would travel from Phoenix, to Chicago, then back and type on your screen "T".
That sucked azz.
The days of way-back.
Sorry, that was way OT....I guess I'm a PW.
Old Mar 6, 2002 | 01:43 PM
funkdaddysmack's Avatar
That sucked azz.
I'm learning CLP on an AS400 right now... fun stuff... fun meaning not fun at all
Quickywd01
Sep 21, 2016 09:36 PM
The Wizard
24
Oct 1, 2015 08:47 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
14GmMax
Sep 19, 2015 11:32 PM
carid
Sep 17, 2015 05:00 AM
