Question about corner lights......
Old Mar 5, 2002 | 05:06 PM
SilverBullet98's Avatar
I am guessing that the corner lights on my 98 are not supposed to get brighter when I turn the signal on like my 1990 Max did....I hope its not supposed to because mine doesnt... I saw the rewire instructions on custommaxima.com , will this cause the bulbs to burn out ?? I put Eurolite Xeonon 1157's in there....but they look almost the same as stock...My headlights are hyper white with blue color also...Will Polargs match better with the re-wire...Blue color ???
Old Mar 5, 2002 | 05:43 PM
MaximaRacer's Avatar
the Polargs and Eurolite will look the same. The rewire will not burn out the bulbs. If it did people wouldnt do it now would they..
Old Mar 6, 2002 | 02:01 AM
Prolepsis's Avatar
Re: Question about corner lights......
The 97 and up corners aren't supposed to get brighter when you are turning, why they changed it baffles me. The reason your Xenon bulbs don't look much different than stock is that the factory setup uses the dimmer of the two filaments in the bulb. The rewire makes the brighter filament light up instead. It is when this brighter filament is lit that you will see the real difference in brightness between the Xenon bulbs and stock ones. As far as color goes, I doubt that Polargs will be much different than the Eurolights. Unless your headlights are also Polarg, either brand should match about as well as the other.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
