95 -> 97 quick conversion question (HELP)
Old Mar 7, 2002 | 07:43 PM
Finality's Avatar
Just a quick one already looked through the stickies but no one seems to have really addressed this.
I plan on putting the Trenz Grille in and I noticed after removing the 95 grille that it does not appear that the Trenz Grille can bolt onto the 95 grille. So other than getting a 97 Grille which would be a total waste of money what can I do?
Regards to the fog lights I just realized that the fog lights to do not swap in I need to basically take off the entire front bumper again???? Is that true or am I just missing something I am missing? It seems to mount directly onto the bracket behind the bumper.
If that is the case what are my options? I was planning on ordering some cheap AM fog lamps as the OEMs are so frigin expensive.
Either I go to the dealer and buy new fog lamps to replace my 95s or I just leave them out for now and waste another 3 hours putting the bumper back on.
Old Mar 7, 2002 | 07:47 PM
Vyrus's Avatar
Re: 95 -> 97 quick conversion question (HELP)
Are you talking about the '97-'99 Trenz Grill? If so that will not fit unless you swap a '97-'99 bumper along with it. Can you be more specific?
If you did a '97-'99 bumper swap, not the '95-'96 fogs will not fit. You need a seperate set of OEM fogs and yes they are pricey .
-Cyrus
Old Mar 7, 2002 | 07:59 PM
ereet's Avatar
Re: Re: 95 -> 97 quick conversion question (HELP)
Grrr Where were you 4 months ago when I sold my SMX grille painted-to-your-color-car for cheap. I woulda traded it in a second for a Trenz heh.
Old Mar 7, 2002 | 10:05 PM
Finality's Avatar
Re: Re: Re: 95 -> 97 quick conversion question (HELP)
No chance the Trenz is mine!
Yep I did the bumper swap. Looking at the bumper parts it does not even seem important to have a 95/97 bumper seeing as its the grille that makes the difference when attaching the Trenz Grille? How do I ghetto rig the Trenz grille so that it fits on my max? From the instructions I read regarding the Trenz grille it just bolts onto the 97 grille. Didn't realize that earlier.......
I was actually putting it on at about 8pm or so when I realized that I would have to remove the entire housing simply to put on the fog lights. Not sure if its worth my time re-doing the bumper when I buy the fog lights again, or wasting all the money on the fog lamps.
Is there no easy way to attach the fog lamps?
Old Mar 8, 2002 | 07:12 AM
Dreizehn's Avatar
I did the front end swap and also have the 97-99 Trenz grille... It wasn't the easiest, but I did get it to fit. I replaced the bumper, headlights, fogs, and grille...
You can get and 97-99 OEM fog kit from www.courtesynissan.com for $200. It has both lamps, relay, and switch. I'm guessing you just need the lamps, but this is probably the best price you will find.
Hope this helps.
Mar 12, 2020 12:06 AM
kjlouis
Sep 14, 2015 11:22 AM
ef9
Buyer/Seller Feedback
Sep 10, 2015 10:13 PM
Hdnseek
Sep 9, 2015 05:55 AM
Johnny9595
Sep 3, 2015 05:18 AM
