What to do at 60k miles???
I personally would do..
Oil/Transmission Fluid Change
Spark Plugs & Wires
Timing Belt
Fuel Filter
Radiator Service
Air Filter (That's if you still have factory airbox)
Check Hoses
Check Battery
Tighten throttle cable
This is what i would do, that is what we did at Jiffy Lube when i use to work there.... everything except for the throttle cable.
Spark Plugs & Wires
Timing Belt
Fuel Filter
Radiator Service
Check Hoses
Check Battery
Get an Owner's Manual at no charge!
Originally posted by Screaminfast
Sorry about posting such a dumb question, but i lost my owners manual, and I haven't bought a repair manual yet so.... What are the things I need to do for 60k tune up?
The Nissan owner’s manual has valuable model-specific details on the day-to-day use and care of your car, as well as recommended maintenance intervals. If you’ve lost or misplaced your manual, just call 1-800-247-5321 between 8 a.m. and 8 p.m. eastern time, Monday through Friday. There is no charge for 1999, 1998 or 1997 manuals, however, there is a $12.00 charge for owners manuals prior to the 1997 models.
Screaminfast... here is what I did...
1. Change oil, and oil filter
2. Change Tranny Fluid
3. Change Spark Plugs
4. Change Fuel Filter (get factory one)
5. Drain and refill radiator (there is a plastic philips screw underneath the radiator.. you'll see a hole under where the screw is)
6. Inspect yo s**t
6. Inspect yo s**t
Re: Screaminfast... here is what I did...
6. Inspect yo s**t
6. Inspect yo s**t
PCV valve and drive belts..>
These items usually get overlooked when tuning up the car.
The valve can get clogged with oil so replace it, cost is
about $6.
<A HREF=http://integra.vtec.net/geeser/megamax/60k_service.html>60,000 mile tune-up</A>
about $6.
Re: PCV valve and drive belts..>
about $6.
about $6.
Turbonut
46
Oct 21, 2015 08:28 PM
JoshG
51
Sep 21, 2015 10:41 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
hntwhttail
Sep 12, 2015 03:43 PM
