help hayden 404 trans cooler
hello poeple i jus thad a hayden 404 trans cooler installed yesterday. my mechanic just pu *** in with out reading the instruactions. when i got home i was reading over the instuctions fromt the box and noticed that it says the return line should be cooler then the line coing out. my problem is that the cooler line out to the tranny is the hotter one. im just curious if it was installed right or if it dosn't really matter. there are two tubes coming out of the tranny. the lower one is going to the radiator then it comes out of the radiator into the tran cooler out of the trans cooler into the tranny is that right????? any help whould be greatly appriaciated. i did a search and came up with noting.
thanks
thanks
Re: help hayden 404 trans cooler
thanks
thanks
I just did mine yesterday.
You should have done it yourself man. Shame on you. Anyway. I think you said it correctly. The flow goes out the lower one into the stock cooler in the radiator. After that it should go to your Hayden cooler and out of that to the return line where the upper hose was. You're fine.
Re: Re: help hayden 404 trans cooler
yay koo he didn't charge me so its koo. family friend hehe i was wooried cause the tranny did a automatic neutral drop by itself today scared the hell outof me.
tarun900
19
Dec 20, 2021 06:57 PM
hayne
Oct 5, 2015 11:53 AM
ef9
Oct 4, 2015 08:43 AM
